Port Adapters for PBP — Ethernet, HDMI, etc.
(08-24-2019, 12:41 PM)CampGareth Wrote:
(08-24-2019, 10:31 AM)zaius Wrote:
(08-19-2019, 12:16 AM)CampGareth Wrote: USB C to HDMI should "just work" if the adapter uses the displayport alternate mode. Some adapters will include a tiny USB GPU and it's those models which won't work on the pinebook Pro.
I'm hoping to get better information soon. The store just reads "USB 3.0 Type-C ports with alt-mode display out".  There are five different "alt-mode display" specifications.  As far as I can tell, DisplayPort alternate mode requires an adapter with active circuitry, HDMI mode only requires wiring one connector to another.
I think the HDMI alt mode is uncommon, partly due to HDMI's licensing costs and partly due to HDMI being a couple of years late to the party. While wikipedia's list could be incomplete it's pretty damning to see only one device with HDMI alt mode: https://en.wikipedia.org/wiki/List_of_de...over_USB-C
I do agree that the store could be clearer about this, looking around at other RK3399 based dev boards they'll usually clarify what goes over the USB-C port, e.g. "USB-C (USB 3.0 + DP 1.2)"
The USB-C is DP alt mode which is common one. The store has updated with the DP info.
RE: Port Adapters for PBP — Ethernet, HDMI, etc. - by tllim - 08-30-2019, 12:28 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 5 7,393 01-02-2026, 04:26 AM
Last Post: stu73
  HDMI and PBP USB C port IMSAI8080 0 2,244 09-26-2022, 09:17 AM
Last Post: IMSAI8080
  PBP (PPP) docking deck : no hdmi sound Rosbeefandino 0 2,003 07-24-2022, 06:19 PM
Last Post: Rosbeefandino
  Ethernet issue on USB-C Docking Deck Nongorre 2 4,724 02-19-2022, 10:18 PM
Last Post: angeloweb
  Pinebook Pro Docking Deck Ethernet Port MickTheGeek 1 3,966 06-16-2021, 07:49 PM
Last Post: Kuawi
  PBP USB-C Docking Deck HDMI 4k upto 60fps possible? Paull 2 5,447 02-27-2021, 11:35 PM
Last Post: Paull
Photo PineBook Docking Deck charging port? ColoBill 3 8,086 02-26-2021, 10:07 PM
Last Post: Paull
  Left USB port stopped functioning firebrd_1979 2 6,315 06-07-2020, 05:51 PM
Last Post: firebrd_1979
  Exposed vias for RGMII Ethernet ky56 1 4,201 05-22-2020, 09:55 AM
Last Post: Arwen
Information Working USB-C Adapter with HDMI, Ethernet and Power kito 0 3,829 01-08-2020, 08:01 AM
Last Post: kito
