The PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter
(08-12-2019, 09:58 AM)thequux Wrote: 0.1W active, 0.04W idle, according to ARK . It's the same for the 2TB variant (which I got), and ARK is pretty definitive. Even has a link to the datasheet (which mostly repeats the same specs)
Active consumption quoted by vendors is usually averaged over some 'normal' use-case scenarios. The power rails still need to be able to supply the top draw of the device for short instances.
FWIW, I'm currently using a WD Blue SN500 NVMe with my RK3399 SBC, and though its average rating is sub-0.1W, its 'heavy-duty' is 2.7W, while its peak (as in absolute peak, sustained up to 10us) is 1.8A (x 3.3V = 5.9W). Keep in mind that's a very power-efficient model, top performers (Gen3 x4) can be rated up to 3A and then some.
RE: The PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter - by blu - 08-13-2019, 02:39 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 2 550 04-09-2024, 04:33 AM
Last Post: maxjrh
  Pinebook Pro on Debian 12 Power Issue u974615 1 347 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 290 02-17-2024, 07:06 PM
  New Working nVME gilwood 0 232 02-12-2024, 08:46 AM
Last Post: gilwood
  Pinebook Pro charging issues tomekdev 1 628 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,111 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 130,739 09-13-2023, 03:43 AM
Last Post: k3dAR
  NVME problems 2022 / Intel 660p 1TB Starbug 1 1,566 04-04-2023, 12:16 PM
Last Post: globaltree
  PineBook Pro dead ottahe 9 6,050 01-18-2023, 07:41 PM
Last Post: ottahe
  Pinebook Pro malfunctioned hardware samtux 10 4,451 12-27-2022, 03:31 PM
Last Post: samtux
