pinebook black screen when booting with "different power mode than last used"
(04-27-2020, 04:27 AM)tranhoangnguyen03 Wrote: I have the same issue after leaving PBP to charge over 2 nights without usage. However, I have tried turning off and on again for tens of times over the past 3 days with no luck. Screen back light is on, power light is green flickering occasionally, Cap Lock light is responsive, Pause/Break light is responsive, but the screen is black. I tried to enter terminal using Ctrl Alt F1 and to issue poweroff command, but that didn’t work.
Is this it for my PBP?
Since your issue concerns the PBP and not the PB(1080), you should try posting your issue in one of the PBP subforums. It'll help your chances of finding a resolution faster.
RE: pinebook black screen when booting with "different power mode than last used" - by tophneal - 04-27-2020, 06:27 AM
  DietPi OS for Pinebook MichaIng 3 5,335 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,730 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 878 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 678 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,563 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,212 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,828 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,220 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,798 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,789 12-25-2020, 04:40 PM
Last Post: ford442
