How the power button is supposed to work?
Got the same problem. A short press on the power-button and the screen turns greyscale and then off.
If i press a button on the keyboard/mouse within ONE second it wakes up again. If it takes any longer than that single second the TV shows "No input" message and nothing turns the Pine back on. I can force-shutdown the pine by holding the power button for ~10sec. But just pressing the button does nothing.
I can allso mention that when forcing the pine off I can only turn it back on by pressing the "reset" button or unplugging and reinserting the powercable.
For the record I'm on Android 0216-build with my 2Gb Pine A64+
RE: How the power button is supposed to work? - by Tarjei85 - 04-26-2016, 10:00 AM
  Android 7.0 - best way to shutdown without root / button saviod 2 3,982 04-19-2018, 02:14 AM
Last Post: Harlan Mueller
  USB GPS dongles that work with Android on Pine64+ ? trondkj 2 4,481 11-16-2017, 02:14 PM
Last Post: Skivholme
  Does snapchat work on pine64 with android? user875545 1 4,241 08-29-2017, 12:05 AM
  How to power off Android on Pine64 johnsl 18 23,367 12-19-2016, 07:11 PM
Last Post: Toriless
  anyone make pine64 lcd hdmi work simultaneously bokeer 4 7,041 12-11-2016, 05:57 PM
Last Post: Luke
  Power on with IR pine64 remote aspixel 17 20,052 11-11-2016, 12:58 PM
Last Post: MarkHaysHarris777
  ethernet does not work with Android 5.1.1 Image Release 20160711 (Known Problem) mathiraj 18 24,167 10-29-2016, 04:31 AM
Last Post: joe
  pine64 a piece of work water 4 6,003 10-28-2016, 07:41 AM
Last Post: jkmooney
  buring image with 'dd' on linux doesn't work (Solved) mathiraj 2 5,655 10-17-2016, 11:42 AM
Last Post: mathiraj
Sad Airmouse doesn't work on any Android ameth 0 2,630 09-11-2016, 06:29 AM
Last Post: ameth
