Manjaro ARM for Pinebook
#34
(12-10-2018, 07:19 AM)Surehand53 Wrote: Hi.
If you face problems with the Wifi connection when on battery like me then you can try a parameter for the wifi driver config file 8723cs.conf.
The parameter will turn off wifi power management.
To add the parameter you have to open 8723cs.conf with an editor of your choice and use sudo to get system access rights.
e.g.
Quote:sudo notepadqq /etc/modprobe.d/8723cs.conf
Add rtw_power_mgnt=0 at the end of the one line in that config file. In the end it should look similar to this (the MAC address will be different)
Quote:options 8723cs rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0
Then save and reboot.
Since I used this change connection did not drop once.
Please test and reply if it works for you.
Also it would be interesting to know if you experience any difference in battery life when the wifi power management is turned off. So far I have not noticed a difference but there might be other experiences.
KDE version installed now and running smooth. However, I still have the wifi disabled. I tried editing that config file but it was already set with the change you suggested.
Anyone else have a fix or work-around for this issue to get wifi working again?
(03-28-2019, 06:37 AM)Luke Wrote: Apparently manjaro KDE on eMMC is super smooth.
Good to know! It's running pretty good on the SD, so I think I'll go ahead with installing it to eMMC. Just need to figure out how to get wifi working again...
Manjaro ARM for Pinebook - by erchache2000 - 11-13-2018, 02:36 AM
RE: Manjaro ARM for Pinebook - by pineuseran - 03-24-2019, 12:10 AM
RE: Manjaro ARM for Pinebook - by pineuseran - 03-26-2019, 08:31 PM
RE: Manjaro ARM for Pinebook - by Luke - 03-27-2019, 04:42 AM
RE: Manjaro ARM for Pinebook - by soupbowl - 03-24-2019, 11:25 AM
RE: Manjaro ARM for Pinebook - by MECZero - 03-28-2019, 06:29 AM
RE: Manjaro ARM for Pinebook - by Luke - 03-28-2019, 06:37 AM
RE: Manjaro ARM for Pinebook - by Luke - 03-24-2019, 05:34 PM
RE: Manjaro ARM for Pinebook - by MECZero - 03-28-2019, 08:03 AM
RE: Manjaro ARM for Pinebook - by erchache2000 - 04-03-2019, 01:54 AM
RE: Manjaro ARM for Pinebook - by MECZero - 04-07-2019, 10:27 AM
RE: Manjaro ARM for Pinebook - by unixfox - 04-14-2019, 07:34 AM
RE: Manjaro ARM for Pinebook - by erchache2000 - 05-28-2019, 02:35 AM
RE: Manjaro ARM for Pinebook - by trigger - 06-12-2019, 06:50 AM
RE: Manjaro ARM for Pinebook - by tophneal - 06-18-2019, 12:22 PM
RE: Manjaro ARM for Pinebook - by schinfo - 04-15-2019, 06:55 AM
RE: Manjaro ARM for Pinebook - by soupbowl - 05-17-2019, 10:44 AM
RE: Manjaro ARM for Pinebook - by trigger - 05-17-2019, 12:42 PM
RE: Manjaro ARM for Pinebook - by trigger - 05-24-2019, 04:49 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 05-28-2019, 12:29 AM
RE: Manjaro ARM for Pinebook - by tophneal - 05-31-2019, 06:56 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 06-20-2019, 01:52 AM
RE: Manjaro ARM for Pinebook - by trigger - 06-20-2019, 07:24 AM
RE: Manjaro ARM for Pinebook - by SKG - 06-21-2019, 03:20 AM
RE: Manjaro ARM for Pinebook - by halbth - 07-11-2019, 09:24 AM
RE: Manjaro ARM for Pinebook - by SKG - 07-11-2019, 09:49 AM
RE: Manjaro ARM for Pinebook - by halbth - 07-12-2019, 08:12 AM
RE: Manjaro ARM for Pinebook - by tophneal - 07-12-2019, 09:39 AM
RE: Manjaro ARM for Pinebook - by Luke - 07-12-2019, 10:14 AM
RE: Manjaro ARM for Pinebook - by tophneal - 07-12-2019, 01:35 PM
RE: Manjaro ARM for Pinebook - by halbth - 07-14-2019, 05:42 AM
RE: Manjaro ARM for Pinebook - by tophneal - 07-01-2019, 10:55 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 07-16-2019, 02:09 AM
RE: Manjaro ARM for Pinebook - by rckt - 07-19-2019, 09:00 AM
RE: Manjaro ARM for Pinebook - by Luke - 07-19-2019, 05:05 PM
RE: Manjaro ARM for Pinebook - by stuartiannaylor - 07-20-2019, 03:38 AM
RE: Manjaro ARM for Pinebook - by Luke - 07-20-2019, 04:09 AM
RE: Manjaro ARM for Pinebook - by fitter - 08-29-2019, 08:36 AM
RE: Manjaro ARM for Pinebook - by tophneal - 08-30-2019, 12:01 PM
RE: Manjaro ARM for Pinebook - by fitter - 09-05-2019, 03:07 AM
RE: Manjaro ARM for Pinebook - by halbth - 09-03-2019, 03:13 AM
RE: Manjaro ARM for Pinebook - by schinfo - 10-23-2019, 02:55 AM
RE: Manjaro ARM for Pinebook - by SKG - 10-23-2019, 03:20 AM
RE: Manjaro ARM for Pinebook - by fitter - 11-08-2019, 07:36 AM
RE: Manjaro ARM for Pinebook - by bvbfan - 03-04-2020, 01:14 PM
RE: Manjaro ARM for Pinebook - by tophneal - 03-04-2020, 01:50 PM
RE: Manjaro ARM for Pinebook - by bvbfan - 03-05-2020, 12:12 AM
RE: Manjaro ARM for Pinebook - by bvbfan - 03-05-2020, 01:21 AM
RE: Manjaro ARM for Pinebook - by tophneal - 03-05-2020, 07:15 AM
RE: Manjaro ARM for Pinebook - by mspohr - 04-27-2020, 01:57 PM
Microphone not working - by telle - 05-10-2020, 02:06 PM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-12-2020, 09:46 AM
RE: Manjaro ARM for Pinebook - by tophneal - 10-12-2020, 10:47 AM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-12-2020, 02:13 PM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-13-2020, 03:26 AM
RE: Manjaro ARM for Pinebook - by tophneal - 10-13-2020, 06:43 AM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-13-2020, 06:57 AM
RE: Manjaro ARM for Pinebook - by tophneal - 10-13-2020, 06:59 AM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-13-2020, 07:23 AM
RE: Manjaro ARM for Pinebook - by tophneal - 10-13-2020, 07:31 AM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-13-2020, 08:26 AM
RE: Manjaro ARM for Pinebook - by acid andy - 10-13-2020, 09:32 AM
RE: Manjaro ARM for Pinebook - by Corkonian - 10-13-2020, 09:49 AM
RE: Manjaro ARM for Pinebook - by Mr.Fermer - 11-29-2020, 04:36 PM
RE: Manjaro ARM for Pinebook - by Luke - 11-13-2018, 03:56 AM
RE: Manjaro ARM for Pinebook - by bvbfan - 11-17-2018, 11:54 PM
RE: Manjaro ARM for Pinebook - by pineadmin - 11-19-2018, 04:06 AM
RE: Manjaro ARM for Pinebook - by sundog - 11-19-2018, 08:19 AM
RE: Manjaro ARM for Pinebook - by Luke - 11-19-2018, 08:30 AM
RE: Manjaro ARM for Pinebook - by Surehand53 - 11-19-2018, 04:28 PM
RE: Manjaro ARM for Pinebook - by Luke - 11-19-2018, 04:31 PM
RE: Manjaro ARM for Pinebook - by bvbfan - 11-20-2018, 06:20 AM
RE: Manjaro ARM for Pinebook - by Surehand53 - 11-20-2018, 10:32 AM
RE: Manjaro ARM for Pinebook - by erchache2000 - 11-22-2018, 03:32 AM
RE: Manjaro ARM for Pinebook - by Surehand53 - 11-22-2018, 10:24 AM
RE: Manjaro ARM for Pinebook - by Luke - 11-23-2018, 01:40 AM
RE: Manjaro ARM for Pinebook - by Surehand53 - 11-23-2018, 06:50 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 11-28-2018, 01:46 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 12-06-2018, 10:50 PM
RE: Manjaro ARM for Pinebook - by Surehand53 - 12-10-2018, 07:19 AM
RE: Manjaro ARM for Pinebook - by rpm - 12-10-2018, 01:53 PM
RE: Manjaro ARM for Pinebook - by erchache2000 - 12-13-2018, 04:23 AM
RE: Manjaro ARM for Pinebook - by Luke - 12-14-2018, 07:07 AM
RE: Manjaro ARM for Pinebook - by erchache2000 - 12-17-2018, 06:36 AM
RE: Manjaro ARM for Pinebook - by tahf - 01-09-2019, 06:42 PM
RE: Manjaro ARM for Pinebook - by erchache2000 - 01-30-2019, 03:41 AM
RE: Manjaro ARM for Pinebook - by pineadmin - 02-19-2019, 02:08 AM
RE: Manjaro ARM for Pinebook - by MECZero - 03-19-2019, 11:34 AM
Manjaro 19.3 released for the Pinebook - by Luke - 03-20-2019, 05:22 AM
  DietPi OS for Pinebook MichaIng 3 5,344 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,779 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 884 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 679 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,564 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,213 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,834 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,224 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,802 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,790 12-25-2020, 04:40 PM
Last Post: ford442
