Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
#70
(02-28-2019, 12:28 PM)Mrfixit2001 Wrote: MisterA - Jan - thanks for reaching out. I see you actually have this error in your dmesg: "bad mode: 0 [#1] SMP". So far I've only had one other user with this issue, others are having good success with pcie. My research in this error suggests a power issue. Can you confirm your power supply, and that you're powering your pcie disks externally? If you gather more logs from boots where pcie does not work for you, please provide them.
Hi Mrfixit, MisterA,
First off: thanks for all your hard work MrFixit Smile Really happy to see that a stable build for the RockPro64 is being worked on!
Just tried your latest build (22.02.2019) and it runs smooth from eMMC here. I can SSH into it and it has internet access, so I can install packages and play around with it.
I have two issue though:
- The white indicator LED keeps blinking instead of burning steadily. I don't know if this indicates a problem as the system seems to be running fine, and I couldn't find anything about this in the documentation.
- My RAID controller (a HighPoint Rocket 640L, which I believe uses the Marvell 88SE9230 chipset), connected through PCI-e, is also not recognized:
root@localhost:/home# lspci
00:00.0 PCI bridge: Device 1d87:0100
The RAID controller chipset gets extremely hot (as in: can't touch it) after a short while though, and I see the same error showing up in my dmesg log as MisterA:
[ 1.743287] Internal error: Oops - bad mode: 0 [#1] SMP
Attached you can find my dmesg output. The error can be found on line 1035.
My RockPro64 is powered by the 'official' (EU) 12v 5A PSU and the two hard drives I have connected receive power from the RockPro itself through the 'official' power cable for SATA drives.
An interesting fact may be that I had Arch-ARM running on the RockPro64 before, and it seemed to be able to at least recognize the RAID controller; it showed up when I typed lscpi.
Do you have any idea what might be going wrong? If there's anything I can do to help/test any furter, please let me know Smile
Thanks in advance!
.txt   dmesg.txt (Size: 77.24 KB / Downloads: 454)
PinePhone (BH 2GB + CE 3GB) // RockPro64 4GB (rev. 2.1) - OMV NAS // PineH64 3GB (model B) - off-prem OMV NAS // Pine64-LTS 2GB (rev. 1.2 + Playbox) - Domotics server
RE: Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D - by p1x3l3d - 03-05-2019, 09:24 AM
  RK3399 PCIe enumeration jhadd 0 2,025 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 5,454 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,165 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 6,691 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,822 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 5,030 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,311 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,558 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 2,043 02-17-2022, 12:10 PM
Last Post: flounder
