Installer does not work for me
(11-25-2018, 06:09 PM)cvmiller Wrote: If you have a smaller SD card, try that. I have had good success with 16GB SD cards using the installer.
Yes, HDMI doesn't work on KDE Neon. I understand the newer kernels like  what is used in AOSC will support it, but it is still sketchy where there is support for the HDMI.
I tried 2 other cards
Samsung 16 gb class 10
sandisk 32 gb ultra class 10
tested both of the card with h2testw no issues and i used them for other purposes as well
I get same error on both of them
Whatinstaller version are you using? I am using the latest one
Also for anyone using KDE neon can you guys test pricegrabber and slickdeals for loading times?
These sites take over a minute to load  on kde neon.. i realize that websites that are loading multiple images like these  may take a bit longer but my windows and android tablets that have the same amount of ram only take like 5-6 seconds to load them
Installer does not work for me - by Tofu - 11-25-2018, 12:59 AM
RE: Installer does not work for me - by cvmiller - 11-25-2018, 06:09 PM
RE: Installer does not work for me - by Tofu - 11-25-2018, 10:31 PM
RE: Installer does not work for me - by cvmiller - 11-26-2018, 10:02 AM
RE: Installer does not work for me - by Tofu - 12-02-2018, 12:55 AM
  Booting with TOC0 u-boot -- should it work? dreadbit 0 783 11-24-2022, 10:19 AM
Last Post: dreadbit
Bug No Images work except one. psiie 3 5,839 05-15-2020, 02:09 AM
Last Post: pfeerick
  Could the Pinebook work as a file server? zer0sig 0 2,004 10-22-2019, 02:36 PM
Last Post: zer0sig
  Cannot get sound to work on Manjaro LXQT trigger 2 4,380 06-12-2019, 06:45 AM
Last Post: trigger
  How does the BTO work? maldus 2 4,093 08-08-2018, 08:49 AM
Last Post: sez11a
Question Installer shows SD Card size 0GB atr.mbl 1 2,982 08-16-2017, 11:13 PM
Last Post: MarkHaysHarris777
  Do I really need PINE64-Installer? anaumov 13 13,533 08-14-2017, 04:47 PM
Last Post: shirman
  Pine64 Installer Utility Luke 0 6,178 04-26-2017, 04:57 AM
Last Post: Luke
