OTG on Android
(11-12-2018, 09:52 AM)onderbetaald Wrote: Hi,
I'm planning on buying the ROCK64 for a project. I'm looking for a single board computer that can run Android to be used as a USB gadget / slave. The ROCK64 seems to be just what I'm looking for, since it has a USB OTG port.
However, I cannot find anyone using the ROCK64's USB gadget / slave capabilities while running Android. I was wondering whether this works in Android, i.e. are all the right USB drivers available and working within the Android distribution? And if so, is there a link out there explaining how to set up the USB OTG port in slave mode (if any special actions are required)?
Thanks!
I am not sure if I understand your question correctly.
you want to connect your pc via a usb cable with the rock to make something there?
transfer data?
I could test it in principle times and let you know if it worked but for that I would have to know exactly what you have in front. Since I only use a translator, I'm not sure what your goal is. please describe exactly what you want to connect and what you want to do then I like to test it for you.
greeting geno
OTG on Android - by onderbetaald - 11-12-2018, 09:52 AM
RE: OTG on Android - by geno - 11-13-2018, 04:13 AM
RE: OTG on Android - by onderbetaald - 11-13-2018, 05:33 AM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 5,340 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 6,063 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 4,596 06-27-2021, 02:38 PM
Last Post: clach04
  Android Images (ROCK64) pineadmin 73 169,093 05-04-2021, 01:58 AM
Last Post: zet_lab
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 4,043 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 3,525 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 6,069 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 2,597 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 4,758 09-18-2020, 07:58 PM
Last Post: BowerR64
  Can't boot android 9 on rock64 maks2204 5 8,875 09-09-2020, 08:44 AM
Last Post: BowerR64
