Write SPI Flash don't work
Good morning, this is morning.
I tried over 20 times on the conditions you presented.
However, we were unable to obtain a different result from the previous report.
I tried different things by changing the point of view.
I have two "ROCK64" units.
One is the one I used for the last time and the report this time, it is "ROCK64 (RAM-4G)"
I tried and checked with the other "ROCK64 (RAM-2G)"
With "ROCK64 (RAM-2G)", there was no problem even for cards with frequent errors.
I will write out the details of 2 cards I tried
Card-A) Silicon Power microSDHC 8GB Class10 with Adapter
Card-B) TOSHIBA EXCERIA UHS-I microSDHC 16GB class10
In order of card-grade, (including your card)
hi-grade             <->          lo-grade
Your-EVO >=  Card-B)  >  Card-A)    : Card Grade
 Crash             Many-Err      Good      : Result of "ROCK64"
Will be
From this, I guess that "cards with higher grade are more prone to problems."
However, it is not a problem of the card itself,
a problem with the "ROCK64" side including the driver.
The point that pointed out your log in the previous report means the above.
"Your-EVO" is "fall-back" to 25MHz after failure occurred at initialization.
This is "Card-A)" below, it is far below the performance of the original card.
And that is probably a problem on the "ROCK64" side, not doubting your card.
Write SPI Flash don't work - by djukonline - 04-29-2018, 01:09 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 01:25 PM
RE: Write SPI Flash don't work - by djukonline - 04-29-2018, 02:11 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 02:56 PM
RE: Write SPI Flash don't work - by pfeerick - 04-29-2018, 05:22 PM
RE: Write SPI Flash don't work - by djukonline - 04-30-2018, 02:39 PM
RE: Write SPI Flash don't work - by pfeerick - 05-01-2018, 03:53 AM
RE: Write SPI Flash don't work - by Luke - 05-01-2018, 04:07 AM
RE: Write SPI Flash don't work - by pfeerick - 05-02-2018, 02:53 AM
RE: Write SPI Flash don't work - by djukonline - 05-02-2018, 12:29 PM
RE: Write SPI Flash don't work - by t4_4t - 05-02-2018, 10:33 PM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 03:48 AM
RE: Write SPI Flash don't work - by t4_4t - 05-03-2018, 05:15 AM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 04:11 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 04:46 AM
RE: Write SPI Flash don't work - by t4_4t - 05-04-2018, 07:24 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 08:47 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 08:44 AM
RE: Write SPI Flash don't work - by pfeerick - 05-05-2018, 08:10 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 11:58 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,407 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  HDMI doesn't work on rock64 Noung1991 1 659 11-21-2023, 08:33 AM
Last Post: as365n4
Sad HDMI doesn't work on rock64 rock7 0 2,820 12-16-2019, 01:04 PM
Last Post: rock7
Bug mpph264enc output doesn't work on bionic rompelstompel 11 16,867 11-15-2019, 10:00 AM
Last Post: gounthar
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,940 05-26-2019, 10:28 PM
Last Post: Wizardknight
  Cannot make DAC Add-on Board work under debian szclsya 0 1,893 09-29-2018, 12:57 AM
Last Post: szclsya
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,865 08-29-2018, 10:08 AM
Last Post: gedas07
  If installing free software system which devices will not work? heocb 6 6,972 08-17-2018, 09:42 AM
Last Post: heocb
  Does AP w/ hostapd with official wifi dongle work? Arsiesys 5 7,234 01-17-2018, 04:03 AM
Last Post: Luke
  H264 hardware encoder not work sueshieh 3 6,575 11-02-2017, 03:57 AM
Last Post: dalmate
