Write SPI Flash don't work
(04-29-2018, 02:11 PM)djukonline Wrote: My problem is that there is no message OK when the led flashes alternately.
I have the feeling that uboot flash is not taken into account.
How long for flashing? I cut the power after one night.
As vincent indicated, this is NORMAL! The uboot-spi-flash image as small as it is because it does one thing only, writes uboot to the SPI flash. It does not have the extra baggage needed to output to a monitor, etc.
If you get the lights blinking, then it should be finished. Leave it for say 10-20 seconds after the lights flash to be sure. But it should take only a minute or two (faster if you're just erasing it).
And once you have powered off the rock64, pull the card out and put a different image on it or put a different card in with a linux or android build on it, otherwise it will just try to write uboot to the SPI flash the next time you power it on (again).
Write SPI Flash don't work - by djukonline - 04-29-2018, 01:09 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 01:25 PM
RE: Write SPI Flash don't work - by djukonline - 04-29-2018, 02:11 PM
RE: Write SPI Flash don't work - by vincent37 - 04-29-2018, 02:56 PM
RE: Write SPI Flash don't work - by pfeerick - 04-29-2018, 05:22 PM
RE: Write SPI Flash don't work - by djukonline - 04-30-2018, 02:39 PM
RE: Write SPI Flash don't work - by pfeerick - 05-01-2018, 03:53 AM
RE: Write SPI Flash don't work - by Luke - 05-01-2018, 04:07 AM
RE: Write SPI Flash don't work - by pfeerick - 05-02-2018, 02:53 AM
RE: Write SPI Flash don't work - by djukonline - 05-02-2018, 12:29 PM
RE: Write SPI Flash don't work - by t4_4t - 05-02-2018, 10:33 PM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 03:48 AM
RE: Write SPI Flash don't work - by t4_4t - 05-03-2018, 05:15 AM
RE: Write SPI Flash don't work - by pfeerick - 05-03-2018, 04:11 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 04:46 AM
RE: Write SPI Flash don't work - by t4_4t - 05-04-2018, 07:24 PM
RE: Write SPI Flash don't work - by pfeerick - 05-04-2018, 08:47 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 08:44 AM
RE: Write SPI Flash don't work - by pfeerick - 05-05-2018, 08:10 PM
RE: Write SPI Flash don't work - by t4_4t - 05-05-2018, 11:58 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,387 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  HDMI doesn't work on rock64 Noung1991 1 636 11-21-2023, 08:33 AM
Last Post: as365n4
Sad HDMI doesn't work on rock64 rock7 0 2,805 12-16-2019, 01:04 PM
Last Post: rock7
Bug mpph264enc output doesn't work on bionic rompelstompel 11 16,810 11-15-2019, 10:00 AM
Last Post: gounthar
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,912 05-26-2019, 10:28 PM
Last Post: Wizardknight
  Cannot make DAC Add-on Board work under debian szclsya 0 1,886 09-29-2018, 12:57 AM
Last Post: szclsya
  Tutorial How to write a image in the eMMc card without USB adaptor or serial cable gedas07 2 3,843 08-29-2018, 10:08 AM
Last Post: gedas07
  If installing free software system which devices will not work? heocb 6 6,928 08-17-2018, 09:42 AM
Last Post: heocb
  Does AP w/ hostapd with official wifi dongle work? Arsiesys 5 7,195 01-17-2018, 04:03 AM
Last Post: Luke
  H264 hardware encoder not work sueshieh 3 6,538 11-02-2017, 03:57 AM
Last Post: dalmate
