PuTTY Disconnected : no supported authentification methods available (server sent : p
(11-21-2017, 01:18 PM)tomtomtom Wrote: I stop, save and restart SSH on OMV and it works well. Tk's for your help .
(11-19-2017, 03:03 PM)tomtomtom Wrote: Hello;
I use PuTTy to connect to the OMV ROCK 64.
I just want to connect simply with login and password.
I try to add a SSH public key, but no success.
So i delete PuTTY, clean config and reinstall.
I try to connect simply with login and password.
But when i put the login, this message appears.
'PuTTY Disconnected : no supported authentification methods available (server sent : publickey)'
Putty stop at :
login as: root
Do you know if i could connect log/pass again or it is a server issue, and the only solution is to fomat / reinstal OMV on the ROCK 64 or may i try to connect directly (with keyboard and screen) the Rock64 ?
Rock 64 - 1 Go Ram - SD Card System on + OMV (Debian) 3.0.88 Erasmus - Linux 44.77 - 118 + Official POWER SUPPLY 3A/5V + Official ACRYLIC OPEN ENCLOSURE.
[Image: 18qm.jpg]
Just disable SSH on OMV; save and re activate, access will come again.
RE: PuTTY Disconnected : no supported authentification methods available (server sent : p - by tomtomtom - 11-26-2017, 03:23 PM
  Headless installation of Real VNC server on Rock64 possible? hg6806 3 5,326 11-18-2019, 04:32 AM
Last Post: evilbunny
  Twonky Server PabloFiasko 0 1,713 07-23-2018, 12:25 PM
Last Post: PabloFiasko
  rock64 is on Armbian's supported boards list cooker 10 10,972 05-17-2018, 01:40 PM
Last Post: KernelPanic
  Shutdown server and corrupt data : how to login ? Florent 2 3,862 02-19-2018, 03:27 PM
Last Post: Florent
  VNC server (x11vnc) Skazochnik 1 3,354 02-11-2018, 01:54 PM
Last Post: S3phi40T
  Which one do you think is the best image for running a server for website? fbms 4 5,321 08-28-2017, 07:19 PM
Last Post: fire219
