pinebook xenial - module snd-usb-usx2y missing
I tried to use pinebook as audio recording machine with a tascam US122, which works fine with most linux flavours after installing alsa-firmware package. But the linux version shipped with the pinebook (upgraded to 3.10.105-bsp-1.2-ayufan-77) lacks the module snd-usb-usx2y, so the soundcard is not recognized.
Downloading the source (alsa-driver-1.0.25+dfsg) and trying to compile (when running configure) gives
checking for directory with ALSA kernel sources... /home/richard/Downloads/alsa-driver-1.0.25+dfsg/alsa-kernel
checking for directory with kernel source... /lib/modules/3.10.105-bsp-1.2-ayufan-77/build
checking for directory with kernel build... /lib/modules/3.10.105-bsp-1.2-ayufan-77/build
checking for kernel linux/version.h ... no
The file /lib/modules/3.10.105-bsp-1.2-ayufan-77/build/include/INCLUDE_VERSION_H does not exist.
Please install the package with full kernel sources for your distribution
or use --with-kernel=dir option to specify another directory with kernel
sources (default is /lib/modules/3.10.105-bsp-1.2-ayufan-77/build).
I could not find out where to get the kernel sources or appropriate include file (version.h). So I'ld like to get some hints how to get/compile that kernel module.
Don't say pinebook is not usable for that task - I tried out with a focusrite saffire 6 USB and audacity, and that worked out of the box even with overdub in high bitrates.
Thanks for your support.
Edit: Linked ../generated/uabi/linux/version.h to /lib/modules/3.10.105-bsp-1.2-ayufan-77/build/include/linux/version.h, so configure could go on. But now it stops with "error: You have built-in ALSA in your kernel.". Does that mean I would have to compile the whole kernel by myself? I think it is not worth trying; if snd-usb-usx2y will not be included in the official kernel in the near future, I'ld have to get some standard compliant USB soundcard.
pinebook xenial - module snd-usb-usx2y missing - by richard - 09-04-2017, 04:25 AM
  DietPi OS for Pinebook MichaIng 3 5,357 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,781 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 884 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 679 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,564 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,213 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,834 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,225 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,802 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,790 12-25-2020, 04:40 PM
Last Post: ford442
