Getting the WiFi/BT Module
(03-30-2016, 09:19 AM)patmolloy Wrote:
(03-30-2016, 05:51 AM)peterz Wrote:
(03-30-2016, 05:30 AM)patmolloy Wrote: Hi, my board arrived today and I now realize I failed to order the WiFi/BT Module. Is it possible to get ahold of one of these separately ? How ?
Thanks !
There will be online shop but not earlier than in May.
It was discussed on this forum somewhere already.
Ah, Ok Sad Sad
There should be possible to use USB WIFI adapter and/or USB Bluetooth adapter.
But drivers might be an issue at the moment (@longsleep if you see this correct me if I'm wrong). You could do it by "attempt/mistake approach" and try several adapters but that might be more costly and lengthy than buying WiFi/BT module from online shop in May.
Getting the WiFi/BT Module - by patmolloy - 03-30-2016, 05:30 AM
RE: Getting the WiFi/BT Module - by peterz - 03-30-2016, 05:51 AM
RE: Getting the WiFi/BT Module - by patmolloy - 03-30-2016, 09:19 AM
RE: Getting the WiFi/BT Module - by peterz - 03-30-2016, 01:47 PM
RE: Getting the WiFi/BT Module - by arpanj2 - 03-30-2016, 03:19 PM
  [split] Better WiFi/BT module? moriel5 3 5,091 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,787 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 25,174 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 4,193 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,160 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,789 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 2,039 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 3,591 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,951 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,086 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
