how to install emmc in just arrived pinebook
You can find all the info on here if you look around a bit ... or open the wiki Wink
But I will make it easy for you (although I recently wrote it up for someone else....):
1) Get the installer utility for your PC (Mac/Win/Linux)
2) Select 'Choose and OS' and Make sure to select Pinebook from the drop down menu (!!!)
3) Choose the OS you want; make sure it says Pinebook eMMC in brackets next to the OS
4) Insert a SD card into your PC
5) flash the image (follow instructions)
6) take the SD out and place it into your Pinebook
7) follow the install to eMMC procedure outlined on screen
RE: how to install emmc in just arrived pinebook - by Luke - 06-29-2017, 08:49 AM
  pinebook 1080p power/barrel connector/cable cel 0 546 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,381 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,232 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,640 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,345 01-03-2022, 03:28 AM
Last Post: kqlnut
  Manjaro/Cinnamon customised on sdcard: how to transfer to emmc? quixote 0 1,519 10-16-2021, 02:03 PM
Last Post: quixote
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,616 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,624 01-13-2021, 11:03 AM
Last Post: barray
  touchpad on pinebook issues? ron_burgundy 14 13,823 12-19-2020, 06:55 PM
Last Post: ron_burgundy
  Pinebook doesn't charge anymore Reinoud 0 2,681 08-20-2020, 08:18 AM
Last Post: Reinoud
