Sopine compatibility with Pi Compute
(02-01-2017, 07:06 PM)temcocontrols Wrote: Am interested to hear from anyone that has checked into the Sopine and just how compatible it is with the Raspberry Pi Compute 3 module. I have a product lined up to use the Pi compute but the Sopine looks interesting.
We have look into the RPi CM3 compatible possibility but prefer not to so do. Below are the few consideration:
1. SoPine use PMU (Power Management Unit) on board and CM lacking such design
2. For GbE, the RGMII is needed and CM doesn't has such setup
3. Prefer the power and ground follows SoDimm pin layout so that if accidently plug SoPine in actual SoDimm board or vice versa, for sure the system will not work and minimum damage harm.
4. SoPine need more pins for IO and prefer SoDIMM DDR3 due to more pins.
RE: Sopine compatibility with Pi Compute - by tllim - 02-01-2017, 10:35 PM
  SOQUARTZ Compute module W does not fit Raspberry Pi CM4 dev board ihab 0 1,589 10-06-2022, 08:46 PM
Last Post: ihab
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 1,761 08-24-2021, 08:17 AM
Last Post: lamson
  [PBP] USB 2.0 devices on left USB-A port compatibility elof 0 1,587 06-05-2021, 04:00 AM
Last Post: elof
  1 of 7 SoPINE compute modules not receiving DHCP lease ClusterMaker 2 3,543 09-08-2020, 03:03 AM
Last Post: Dippywood
  PSCI, u-boot and reboot on Sopine ClusterBoard hbaxmann 0 2,346 09-03-2019, 11:57 PM
Last Post: hbaxmann
  sopine cluster board install Smurfbot 1 4,419 03-31-2018, 04:09 AM
Last Post: pfeerick
  Sopine A64 doesn't boot ubuntu stixcher 5 7,822 12-03-2017, 11:05 AM
  Turning off RPI GPIO 5v on boot (SOPine) TeknoRapture 1 3,001 03-31-2017, 02:48 PM
Last Post: xalius
  Would the SOPINE modules work if they were put into a standard SODIMM RAM slot? Wiooooo 4 6,633 02-05-2017, 02:57 PM
Last Post: MarkHaysHarris777
