Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI
(12-24-2016, 04:21 PM)Shai Wrote:
(12-16-2016, 07:01 PM)speedro86 Wrote: So while on the internet, I stumbled upon an Image of Raspbian for the pine64, it is technically for the banana pi64, but hardware is identical.
 It just so happens this is probably the easiest initial start for anyone new to pine64. First download the link here:
 https://drive.google.com/file/d/0B_YnvHg...sp=sharing
Unzip the folder to get the .img file, and burn the Image to a minimum 8Gb class4 sd card. Once you have got the sd card ready to boot, plug in your hardware you want to use, and boot. HDMI wont boot up instantly, so the first boot really just decompresses .img to its folders and files.
 Shutdown your pine64, put sd card into your windows or mac, or Linux to read the disk, you are looking for Config.txt open this file. Remove the #'s for the commands you want, such as HDMI, save file, eject.
 Now put the sd card back into your pine and boot, you will have linux penguins for a moment, then you will boot into the desktop with USB, Ethernet, HDMI all working. Now you can do raspberry pi projects with your pine64.
Hi - How did you make the network wifi to work?
I've run into the same problem with Raspbian and wifi connection.
What I've done to solve it:
1) Install wifi driver:
git clone https://github.com/hadess/rtl8723bs/
  cd rtl8723bs
  sudo make
  sudo make install
  sudo depmod -a
  sudo modprobe r8723bs
2) "lsmod" should show you Module with "r8723bs" name.
3) Autoload the WIFI driver when you boot the operating system, you should add “8723bs” into the /etc/modules file
sudo nano /etc/modules
8723bs
sudo reboot
Now, you can use your wifi on Pine64 Raspbian build. Have a good day!
RE: Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI - by bunkerWHz - 04-15-2018, 07:37 AM
  linux-headers and quartz64-post-install package conflicts Berzerkleyfan 2 680 12-01-2023, 05:17 AM
Last Post: Berzerkleyfan
  PBP Debian 11 GRUB install error zlth 2 1,952 11-18-2022, 07:42 AM
Last Post: zlth
  RockPro64 ethernet issues: DMA engine initialization failed slowcamp 1 3,089 04-26-2021, 06:03 AM
Last Post: slowcamp
  ISO Smart Mini Portable Soldering Iron cjmones 0 1,913 12-13-2020, 01:34 PM
Last Post: cjmones
  Setting up QT for compiling on my desktop vincer 0 2,067 09-19-2020, 03:31 PM
Last Post: vincer
  wrong launguage install chadace 1 4,052 06-08-2020, 08:31 PM
Last Post: chadace
  How to boot from the SD card and install to eMMC? ravanh 2 6,472 03-18-2020, 09:42 AM
  USB C hub and Ethernet adapter jaysistar 3 6,247 01-20-2020, 04:07 PM
Last Post: belfastraven
  Pine HDMI -> DVI monitor Pineapple 4 7,805 09-10-2019, 11:28 AM
Last Post: Pineapple
  Install OS on RAID1 thanks to dual SATA board? Thatoo 12 15,504 05-15-2019, 02:55 PM
Last Post: Thatoo
