DMG/Classic Gameboy Enclosure!? n_n'
#39
Well, my faulty Gameboy arrived and I wasted no time in gutting it out.
But the news is not good....
That battery compartment takes up so much room and gets right in the way of the Ethernet port/or USB ports (depending on which way up you position the Pine board). So that part of the back would need to be hacked off. Same story for the cartridge slot, that part of the back would also need to be removed...which doesn't leave you with a whole lot of back at all, really.
In addition, the button moulds intrude upon the inside of the case much more (deeper) than I expected. Whilst these could be snipped away, it would make remounting buttons later tricky. The screw mounts are also in the way. Again, these can be cut down, but then you lose the ability to screw the case back together effectively.
All in all, I think if you hacked up the case pretty much to pieces, you could just about cram the Pine board in there. But it would be so cramped that it would be hard to actually do anything with it, like wire up the buttons, fit a battery pack, fit a screen, etc...
Sadly, I just don't think it's feasible Sad
Maybe we could try and make a Super Pinetendo or something instead? That would give us much more room to play with...
RE: DMG/Classic Gameboy Enclosure!? n_n' - by Ghost - 02-04-2016, 06:38 AM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 20,067 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,363 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,527 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,590 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,746 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,119 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 25,139 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 20,180 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,149 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,661 10-13-2016, 08:47 AM
Last Post: Bluphire
