DMG/Classic Gameboy Enclosure!? n_n'
Hmm... I'll just get the one, then; can I fit that inside the Gameboy do you think?? :0c It's a far more portable size, though technically the playBox houses a 7 inch screen which is fairly portable as well... It just won't fit in a sizeable pocket like the Gameboy does Tongue
But if I *don't* get two, does that mean my playBox will forever have to be tethered to a power point via a cable? I won't be able to just pick it up in my room and plonk down in a corner in the lounge room; I'll need to unplug and replug it every time I move locations? :0c
As to the remote... I suppose I'll want to use the pine64 with a TV if I'll be watching shows or playing games on it, unless they're little things like 8-bit, 16-bit, that sort of thing. That'd be better on the screen itself.
Hmm..
Going back to the Pineboy, I'd love to be able to switch it on/off with the original power button~! :3c I think I read something about a port being available for an on/off switch if people so desired?
I'm gonna have to cover the clasp for the battery cover, too. I love the nostalgic clacky sound it makes when I tap my fingers against it, but there's a sizeable gap on either side of the fold of plastic that holds it in place(which I'll have to cut off, making the entryway for dust etc. even bigger, since it definitely goes too deep to *not* be in the way). Hopefully it'll still clack after it's been tacked up, like having a tape-like hinge there instead.
... I should say *we'll* have to Tongue
=DD YESS~! Congrats! Big Grin Phase 0 complete?
...... I need to get some glow in the dark paint... and airbrush some 'galaxies' all over my case! Big Grin
... On *both* sides(internal/external)! =D For 3D effect~
RE: DMG/Classic Gameboy Enclosure!? n_n' - by Gearsoul - 01-28-2016, 05:41 AM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,940 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,153 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,480 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,540 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,719 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,009 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,985 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,997 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,035 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,627 10-13-2016, 08:47 AM
Last Post: Bluphire
