Enclosure issue
The best way to assemble the case so that it can be opened easily is to use a tool ( like the dremel tool ) to drill very small holes ( paper clip diameter holes ) in the case through the outside where each of the latching tabs engages. Opening the case is then as easy as pushing a tool ( like a large paper clip ) into the hole to release the tab.
( credit for this simple idea goes to Needles, on the irc chat )
Enclosure issue - by gates_c - 08-31-2016, 02:12 PM
RE: Enclosure issue - by mldavies - 09-03-2016, 10:21 AM
RE: Enclosure issue - by dedgar - 09-03-2016, 09:29 PM
RE: Enclosure issue - by pfeerick - 09-03-2016, 10:33 PM
RE: Enclosure issue - by MarkHaysHarris777 - 09-03-2016, 10:49 PM
RE: Enclosure issue - by pfeerick - 09-04-2016, 11:03 PM
RE: Enclosure issue - by jhg03a@acu.edu - 09-07-2016, 05:34 PM
RE: Enclosure issue - by dedgar - 09-08-2016, 08:12 AM
RE: Enclosure issue - by jhg03a@acu.edu - 09-08-2016, 08:27 AM
RE: Enclosure issue - by MarkHaysHarris777 - 09-08-2016, 08:38 AM
RE: Enclosure issue - by leon.stankowski - 09-14-2016, 03:09 PM
RE: Enclosure issue - by FrenchFrog - 09-15-2016, 07:44 AM
RE: Enclosure issue - by matteus - 09-15-2016, 10:38 AM
RE: Enclosure issue - by pfeerick - 09-15-2016, 06:29 PM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,984 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,213 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,498 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,555 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,732 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,034 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 25,038 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 20,051 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,079 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,637 10-13-2016, 08:47 AM
Last Post: Bluphire
