Phoenix Card and Norton Security don't mix . . .
(08-16-2016, 07:52 AM)mjgoode Wrote:
(08-16-2016, 06:55 AM)Ghost Wrote: The Script Not Found error usually occurs due to trying to burn a DD image using PhoenixCard, rather than the appropriate PhoenixCard image.
Let us know how it goes.
Understood.  If I had used the wrong image . . . it wouldn't have burned.  I have verified this previously through experiment.   Cool
It's up but seems kinda slow and laggy and it's rolled a bunch of times.  It's a 2GB unit.  Maybe I'm expecting too much or should give up and pick a different OS.
Thanks,
Matthew
Experiment some more and try a different OS, see where you stand after that. Which OS is it that you burned?
RE: Phoenix Card and Norton Security don't mix . . . - by Ghost - 08-16-2016, 01:13 PM
  How to boot from SD card on pinebook pro linux123 3 6,165 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 4,520 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 4,426 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 6,524 03-18-2020, 09:42 AM
  recommended micro sd card ? mronhb 91 214,465 03-03-2020, 11:34 PM
Last Post: siyatalerja
  eMMC card on adapter Malmgren 8 11,378 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 10,196 02-08-2017, 05:42 PM
Last Post: maxpayne
  recommended micro sd card? Gustavo Woltmann 1 3,650 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 3,722 11-03-2016, 02:33 PM
  SD card burn img size problems stephen0205 17 23,803 09-22-2016, 06:28 AM
Last Post: tkaiser
