Wifi module able to share ethernet connection? Connection is unstable!
(08-05-2016, 07:07 PM)cr2016 Wrote: Another thing: after a fresh start the wifi is working but the connection is lost after few minutes; the hotspot does not appear anymore on the phone in the list of available wifi networks. Need to restart to get it back, or there might be a command to restart the network without restarting the pine?!?!
Thanks vigor, I will check that ;-)
I have to say my pine64 access point is pretty solid, it allocates dhcp addresses 10.0.0.1/24 and i connect to it via http and ssh - no problem. I left it running overnight and it was still up this morning.
I noticed - you have to be 7 to 15 feet away from Access point (Pine64) then connection is stable, if you are too close - it does not work at all or unstable.
One thing i noticed about network stack in general, i have to comment out all lines in /etc/network/interfaces.d/eth0
if the ethernet wire not plugged in, then wifi works stable after boot. I am not sure how to handle that, but i would like to run it with only two wifi interfaces - no ethernet wires. The pine64 will be located where there is no wires.
RE: Wifi module able to share ethernet connection? Android now ok, iphone not! - by vigor - 08-06-2016, 08:07 PM
  [split] Better WiFi/BT module? moriel5 3 5,064 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 4,779 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 25,076 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 4,176 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 27,151 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 9,750 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 2,034 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 3,578 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 15,928 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 6,073 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
