Crippling noise from inside pinecil during a few minutes high power soldering.
(10-03-2023, 05:51 AM)dreieck Wrote: I just had a "high power" soldering job with my Pinecil V2 (power supply: 65W USB C PD; soldering task: Thin steel surface) where I had the pinecil set to maximum temperature and constantliy heating the piece where I wanted to solder.
in my case I can here some very weak noise in the Pinecil V2, but it is very low level, but I think it is PWM. In noisy room its can not be heard.
If nothing is heating on the PCB during this noise, so should be fine. If possible, try another PD supply.
RE: Crippling noise from inside pinecil during a few minutes high power soldering. - by Neitron4ik - 10-09-2023, 01:28 AM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 1 273 05-13-2024, 01:31 PM
  Connecting a power supply to the Pinecil jon_bondy 1 524 02-29-2024, 07:37 PM
Last Post: Okedokey
  Best power supply? naviathan 4 4,926 02-29-2024, 07:33 PM
Last Post: Okedokey
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 460 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,648 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 778 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,443 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,706 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,594 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,399 12-14-2022, 01:03 AM
Last Post: River
