PineTab2 screen won't turn back on until reboot
Thanks for pointing me in the right direction! Yeah, LXQT is running under X.  I had to script a loop to repeatedly save that output to a log, since the remote SSH session couldn't talk to the main X session, but what I found is:
  1. DPMS is enabled, with the standby, suspend and off timeouts at 600 -- which it shouldn't be, because LXQt is set to not standby or suspend, but....
  2. There is a bug in LXQT's power management where it doesn't always update DPMS's settings.
  3. DPMS sees the monitor as off.
I also verified that the timeouts, lock screen etc. do still work correctly under Wayland on my device, so that's good to know!
That gives me a couple of approaches (workarounds, or manually installing the newer version, etc.) to prevent the problem of it turning off when I don't want it to. (I really do not miss all that messing with X configuration back in the old days, but hey, you gotta do what works.)
Then I need to figure out how to get it to turn back on. If LxQt's own power management works right (except for the dpms issue), then problem solved. It not, I figure I'll experiment with blank, standby, and suspend to see which ones (if any) the display recovers from.
For the record: Full output of xset -q after the display turns off:
Keyboard Control:
  auto repeat:  on    key click percent:  0    LED mask:  00000000
  XKB indicators:
    00: Caps Lock:  off    01: Num Lock:    off    02: Scroll Lock: off
    03: Compose:    off    04: Kana:        off    05: Sleep:      off
    06: Suspend:    off    07: Mute:        off    08: Misc:        off
    09: Mail:        off    10: Charging:    off    11: Shift Lock:  off
    12: Group 2:    off    13: Mouse Keys:  off
  auto repeat delay:  500    repeat rate:  33
  auto repeating keys:  00ffffffdffffbbf
                        fadfffefffedffff
                        9fffffffffffffff
                        fff7ffffffffffff
  bell percent:  0    bell pitch:  400    bell duration:  100
Pointer Control:
  acceleration:  2/1    threshold:  4
Screen Saver:
  prefer blanking:  yes    allow exposures:  yes
  timeout:  600    cycle:  600
Colors:
  default colormap:  0x20    BlackPixel:  0x0    WhitePixel:  0xffffff
Font Path:
  built-ins
DPMS (Display Power Management Signaling):
  Standby: 600    Suspend: 600    Off: 600
  DPMS is Enabled
  Monitor is Off
RE: PineTab2 screen won't turn back on until reboot - by KelsonV - 08-22-2023, 11:05 PM
  Pinetab2 not starting Corconegre 12 18,959 07-25-2025, 03:04 AM
  cracked screen and repair elix 0 1,486 03-07-2025, 01:40 PM
Last Post: elix
  What is the state of the PineTab2 today? Arcikks 2 1,996 12-04-2024, 08:30 PM
Last Post: dachalife
  pinetab2 hardware is not very good lmartin 13 10,340 07-30-2024, 08:50 AM
Last Post: Piotr Bujakowski
  Pinetab2 Audio Hiss/Static from speakers scottgr 2 2,349 03-16-2024, 11:56 AM
Last Post: scottgr
  Pinetab2 screen removal Corconegre 5 4,725 01-10-2024, 08:08 AM
Last Post: stozi
  PineTab2, Ubuntu Touch and WiFI JMoore 2 2,952 01-07-2024, 10:58 AM
Last Post: JMoore
  Using the Pinetab2's PCIe slot FortunateFowl 0 1,581 12-22-2023, 01:23 PM
Last Post: FortunateFowl
Exclamation Pinetab2 Keyboard Issues lockedpotato 0 1,567 10-14-2023, 05:48 PM
Last Post: lockedpotato
  ?brighter screen replacement for pinetab (>1600 nits) dynobang 0 1,840 09-28-2023, 01:06 PM
Last Post: dynobang
