Battery life thread: discussion, support and tips
(08-10-2023, 03:40 AM)dukla200 Wrote: I use Arch/sxmo mainly, also Arch/phosh (See setup details here.)
In suspend mode get way more than 24 hours - would need to check Megi's pages but think he calculated 36 or so theoretically. I much prefer sxmo in general, but specifically to suspend you KNOW it is suspended when the LED stops flashing!
Active use (browsing, email, telegram, some mpv) maybe 3-4 hours
Note the default cpu governor in Danct12 Arch images is conservative: I change my default to schedutil as don't see the point of permanently doping my cpu. In theory bad for battery but what I get is still fine.
Hoping that I can improve my active use life if I can get Megi's DRAM scaling working.
I just put arch/phosh on the microsd card and am getting a long life (24 hours or more) in suspend mode.  However the ppp is not picking up phone calls.  Is this the same experience you are having, dukla200?  Or do you get 24 hours battery life with phone capabilities while on suspend?
RE: Battery life thread: discussion, support and tips - by apink - 08-12-2023, 12:04 AM
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 44 13,739 05-14-2024, 12:30 PM
Last Post: Rednoise
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,447 04-28-2024, 01:52 AM
Last Post: diederik
  [Mobian] : Battery consumption and OS compatibility freelectro 2 1,149 06-02-2023, 06:55 AM
Last Post: Fred Zyphal
  Phosh Updating - Battery Charge Indicator - Jittery Settings - Display Usability ArchiMark 4 1,512 05-28-2023, 07:00 AM
Last Post: ArchiMark
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,605 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  Mobian has new separate packages to support the PinePhone Pro mburns 22 7,772 04-10-2023, 12:02 PM
Last Post: mburns
  Battery meter slowly reducing under keyboard charger robocone 1 1,412 12-26-2022, 09:37 AM
Last Post: robocone
Exclamation PPP Battery drain + hot CPU GPU Piotr 2 1,604 12-09-2022, 12:45 PM
Last Post: Piotr
  Battery status always "Charging" dabigjhall 2 1,861 03-16-2022, 03:14 PM
Last Post: maltee
  Boot Discussion in PPP Wiki Needs Clarifications tckosvic 7 4,301 02-06-2022, 01:58 PM
Last Post: lllsondowlll
