Battery issues
(07-17-2023, 03:34 AM)alaraajavamma Wrote:
(07-16-2023, 01:21 PM)user641 Wrote: Hello, I installed pmos on my pp yesterday, the phone recognizes battery empty at 15% and sutsdown, tested on 3 cycles. What can i do to fix it?
If I remember correctly you can change the values from this config file:
/etc/UPower/UPower.conf
But I don't have pmos phone with me right now but I am quite sure that it should work.
Inside that file there is something like this:
    PercentageLow=30
    PercentageCritical=15
    PercentageAction=15
And if you changet that PercentageAction for example to 5 then the shutdown will happen in 5%.
Or if you did mean that the battery level is shown wrong then you can for example charge it overnight and see if it helps?
Found it and changed it. Thanks, but why not set it to 0 instead of 5? Does it damages the battery?
Battery issues - by user641 - 07-16-2023, 01:21 PM
RE: Battery issues - by alaraajavamma - 07-17-2023, 03:34 AM
RE: Battery issues - by user641 - 07-17-2023, 08:01 AM
RE: Battery issues - by alaraajavamma - 07-17-2023, 10:43 AM
  Issues after installing latest PostMarket OS with POSH xen314 4 5,946 08-20-2023, 11:18 PM
Last Post: xen314
  Boots To Shell After Dead Battery (PMOS) britelite 0 2,022 02-17-2023, 02:41 PM
Last Post: britelite
  Pinephone 64 PostMarketOS edition Battery Issues, Not Hardware Issue X0X0X0X0X0 1 3,744 02-11-2023, 08:19 AM
Last Post: acid andy
  Pinephone 64 PostMarketOS edition Battery problem Alejandro.SU 9 14,544 12-22-2020, 04:33 PM
Last Post: Alejandro.SU
  pmbootstrap issues IVp 3 8,546 09-24-2020, 02:24 AM
Last Post: Pinethom
  unable to boot the phone with PM OS after battery has completely discharged nieral 1 4,764 08-24-2020, 06:34 AM
Last Post: PureTryOut
  Charging issues and battery life realrichardsharpe@gmail.com 6 10,577 03-11-2020, 09:03 AM
Last Post: MartijnBraam
  Battery life and ways to improve - request for official statement p1trson 0 3,035 03-01-2020, 09:18 AM
Last Post: p1trson
