Chgled Power Reset
(07-21-2016, 07:00 AM)rduerst Wrote:
(07-21-2016, 05:29 AM)MarkHaysHarris777 Wrote: The two-wired switches will work, provided that you connect the correct holes on the board.  Double check with the schematics ; there are four holes on the board but only one of them is important connected against one of the other four; if you get it wrong, you won't hurt anything, it just won't work.
marcus
Awesome. I really appreciate it. Thanks for being so prompt.
Sent from my SM-G930P using Tapatalk
Yes, the two nearer the edge are the actual switch contacts, the two larger ones further back are the mechanical anchor holes for the switch.
The connections are also repeated on the EXP header - Charger LED is 3, PWR/SB switch is 5, Reset is 4 and GND is 9. Connect PWR to GND to power on / send power off interrupt / force power down. Same goes for Reset - connect to GND for reset.
Connector layout
Connector pinouts
Chgled Power Reset - by rduerst - 07-21-2016, 04:55 AM
RE: Chgled Power Reset - by MarkHaysHarris777 - 07-21-2016, 05:29 AM
RE: Chgled Power Reset - by Ghost - 07-21-2016, 06:49 AM
RE: Chgled Power Reset - by rduerst - 07-21-2016, 07:00 AM
RE: Chgled Power Reset - by pfeerick - 07-22-2016, 09:22 PM
  Pine64+ power button PaddyChan 0 2,793 09-14-2020, 09:55 AM
Last Post: PaddyChan
  UK power supply (Pinebook Pro 64) skobi 0 2,314 11-17-2019, 04:55 AM
Last Post: skobi
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 6,375 02-22-2019, 03:25 AM
Last Post: GaryFunk
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,719 05-24-2018, 01:58 AM
Last Post: crapped
  short boot time after power-up bongo 7 10,155 10-31-2017, 08:02 AM
Last Post: bongo
  PINE64/ROCK64 infra receiver power on cserem 1 3,619 10-06-2017, 07:25 AM
Last Post: MarkHaysHarris777
  Power supply questions montero65 36 45,972 08-15-2017, 03:51 AM
  Power-on pine by remote kleintvra 1 2,866 08-11-2016, 02:48 PM
  Pine A64 not powering up / Power button missing vaevictis 10 14,047 07-06-2016, 01:28 PM
Last Post: xalius
  Some hard numbers on Pine64 Power Usage ataylorm 2 8,014 06-27-2016, 06:08 AM
Last Post: ataylorm
