Chgled Power Reset
(07-21-2016, 05:29 AM)MarkHaysHarris777 Wrote: The two-wired switches will work, provided that you connect the correct holes on the board. Double check with the schematics ; there are four holes on the board but only one of them is important connected against one of the other four; if you get it wrong, you won't hurt anything, it just won't work.
marcus
Awesome. I really appreciate it. Thanks for being so prompt.
Sent from my SM-G930P using Tapatalk
Chgled Power Reset - by rduerst - 07-21-2016, 04:55 AM
RE: Chgled Power Reset - by MarkHaysHarris777 - 07-21-2016, 05:29 AM
RE: Chgled Power Reset - by Ghost - 07-21-2016, 06:49 AM
RE: Chgled Power Reset - by rduerst - 07-21-2016, 07:00 AM
RE: Chgled Power Reset - by pfeerick - 07-22-2016, 09:22 PM
  Pine64+ power button PaddyChan 0 2,789 09-14-2020, 09:55 AM
Last Post: PaddyChan
  UK power supply (Pinebook Pro 64) skobi 0 2,309 11-17-2019, 04:55 AM
Last Post: skobi
  Won't power on/boot -- kickstarter A64 2GB fuzzycuffs 3 6,366 02-22-2019, 03:25 AM
Last Post: GaryFunk
  Supply DC power to Pine64 via Pi-2 Connector & Euler Bus? crapped 2 5,709 05-24-2018, 01:58 AM
Last Post: crapped
  short boot time after power-up bongo 7 10,144 10-31-2017, 08:02 AM
Last Post: bongo
  PINE64/ROCK64 infra receiver power on cserem 1 3,617 10-06-2017, 07:25 AM
Last Post: MarkHaysHarris777
  Power supply questions montero65 36 45,895 08-15-2017, 03:51 AM
  Power-on pine by remote kleintvra 1 2,861 08-11-2016, 02:48 PM
  Pine A64 not powering up / Power button missing vaevictis 10 14,029 07-06-2016, 01:28 PM
Last Post: xalius
  Some hard numbers on Pine64 Power Usage ataylorm 2 8,002 06-27-2016, 06:08 AM
Last Post: ataylorm
