P{inebook Pro not charging
After a while charging on the USB-C port the blinking stops and the led is continuously on. There's actually some juice in the battery, (so your tip worked!) but Jackplug charging still does not seem to work - even after switching adapters. Led is on, but apparently there's no current running.
Next step is to get me a new jackplug and see if that solves the issue.
If not I guess it's a boardproblem...
P{inebook Pro not charging - by Ome Ko - 03-08-2023, 08:33 AM
RE: P{inebook Pro not charging - by KC9UDX - 03-08-2023, 04:49 PM
RE: P{inebook Pro not charging - by Ome Ko - 03-11-2023, 03:58 AM
RE: P{inebook Pro not charging - by Ome Ko - 03-11-2023, 05:57 PM
RE: P{inebook Pro not charging - by KC9UDX - 03-12-2023, 02:13 AM
RE: P{inebook Pro not charging - by Ome Ko - 03-12-2023, 04:24 AM
RE: P{inebook Pro not charging - by tomekdev - 11-09-2023, 03:29 PM
  Pine Book Pro Charging Problems balin 7 6,937 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,541 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 4,325 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 2,842 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 1,653 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 5,894 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 35,945 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 20,161 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 3,138 05-30-2020, 06:05 PM
  Charging via USB GloriousCoffee 7 8,716 04-03-2020, 12:01 PM
Last Post: GloriousCoffee
