Pine Phone Pro audio on phone calls: discussion, support and tips
#23
(07-19-2023, 07:03 AM)tckosvic Wrote:
(07-19-2023, 05:40 AM)DominiqueM Wrote: […]
Some Mobian images (like mobian-pinephonepro-phosh-20230709) give other path: /usr/share/alsa/ucm2/Rockchip/PinePhonePro/
Anyway, I have a new annoying problem for phone calls: not sound at all (not outgoing, not incoming).
@Dominique M,  in post prior to the above it was stated that phone audio worked perfectly after sed change from 47 to 160. That was a week or so ago.  When did the complete audio go out, for how long did it work, how many calls did it work on, and did you change anything OS/desktop software related?
thanks,    tom kosvic
10-7-2023 mobian-pinephonepro-phosh-20230709 (was by accident on the page weekly, not a conscious choice). I call my daughter. Microphone too weak. Sudo alsamixer, got better sound with the Sound recorder. Did not try to call at that time.
11-7-2023 I get a call, no sound at all!
12-7-2023 Supposing I may have broken something with Alsamixer, I install mobian-pinephonepro-phosh-20230606 (not weekly to play safe) to get rid of all possible broken config. I call my daughter again and get called back by her. Microphone still too weak. I find advice about 160 instead of 47. Sudo sed -i 47 to 160 in both HiFi and VoiceCall config in /usr. I call my daughter again, sound satisfactory.
One or two calls without sound the following days, unknown numbers, I suppose maybe crooks not speaking to make me call back.
17-7-2023 Incoming call my other daughter. No sound at all. Reinstall package als-cum-conf. No improvement (not even the weak microphone).
18-7-2023 Again install mobian-pinephonepro-phosh-20230709. Sound recorder: weak micro. I try this time 47 to 100 in both HiFi and VoiceCall config in /usr. Recorded sound good. But still no sound at all in phone calls.
I cannot see any special event between success 12-7-2023 (after 47 to 160) and phone call completely broken afterwards.
(07-19-2023, 05:40 AM)DominiqueM Wrote: Some Mobian images (like mobian-pinephonepro-phosh-20230709) give other path: /usr/share/alsa/ucm2/Rockchip/PinePhonePro/
thanks,    tom kosvic
RE: Pine Phone Pro audio on phone calls: discussion, support and tips - by DominiqueM - 07-19-2023, 07:44 AM
Question Calls: ALSA UCM config not making a difference with volume lightwo 6 323 05-17-2024, 04:23 AM
Last Post: lightwo
  Battery life thread: discussion, support and tips apink 7 2,233 05-14-2024, 12:53 PM
Last Post: Rednoise
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 16 2,456 04-28-2024, 01:52 AM
Last Post: diederik
  Guide to Suitable Phone State Borealid 19 11,143 09-18-2023, 07:00 AM
Last Post: robocone
  Phone Attitude(Device orientation) lurkadillian 2 1,113 06-22-2023, 08:12 PM
Last Post: lurkadillian
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,605 05-12-2023, 12:58 PM
Last Post: alaraajavamma
  Mobian has new separate packages to support the PinePhone Pro mburns 22 7,774 04-10-2023, 12:02 PM
Last Post: mburns
  Pine Phone won't boot into recovery mode ninjapig26@gmail.com 3 1,895 02-18-2023, 06:14 PM
Last Post: fxc
  [Mobian] No return from locked phone arno_nuehm 1 1,080 02-06-2023, 07:57 AM
Last Post: arno_nuehm
  Making and receiving calls via command line Zotax 0 861 01-28-2023, 12:19 PM
Last Post: Zotax
