Auto start application on Phosh login
(09-03-2022, 06:56 PM)Zebulon Walton Wrote: How do you set up an application to run automatically when logging into Phosh? I don't see anything in Settings about auto-starting applications at login and don't see anything obvious under .local or .config.
Correct folder to place .desktop file is ~/.config/autostart/
Or install gnome tweaks but it will do excatly the same thing Smile
RE: Auto start application on Phosh login - by alaraajavamma - 09-04-2022, 03:06 PM
  Screen auto-rotation sensitivity mdk 0 278 12-26-2023, 06:08 AM
Last Post: mdk
  Errors when start the system kubussz 2 581 11-21-2023, 11:07 AM
Last Post: kubussz
  Using sway along phosh fdlamotte 2 3,325 05-11-2023, 04:24 PM
Last Post: kabouik
Exclamation Impossible to login since the latest update anonymous 12 4,259 02-26-2023, 01:01 PM
Last Post: anonymous
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,814 02-24-2023, 12:11 AM
Last Post: nexion
  [Fixed] Phosh crashes frequently after latest updates arno_nuehm 20 8,876 10-14-2022, 05:38 PM
Last Post: Krafter
Exclamation Impossible to minimize a window with Phosh anonymous 7 3,428 08-18-2022, 01:53 PM
Last Post: dante404
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 1,736 07-16-2022, 02:28 PM
Last Post: dachalife
  Phosh 0.20 beta on mobian Anthony1224 1 1,638 06-11-2022, 06:29 AM
Sad Chatty can no longer start since the last update anonymous 10 5,406 06-08-2022, 01:03 PM
Last Post: Korac
