Need help with new pinebook pro
I'm guessing we all have the most recent revision of the Pinebook Pro, which is quite recent and has enough different drivers/firmware to make some of the more recent images unusable, it seems. I've had to modify the Debian installer script dramatically to get anything to work, I've had to load non-standard drivers to get WiFi going, and I still can't get memory-based sleep working, but once I do I'll make sure to document it.
Also, using the manjaro-arm-installer script, for some reason it will only work (at least with encryption) if I install it to an SD card -OR- if I install the minimal version and then manually load drivers and firmware for certain devices.
Anyway, I completely intended on tinkering, but it has been a little frustrating that a lot of existing guides seem to just not work as-is.
As an aside, it seems that overclocking the CPU has dramatically cut down on the speaker whine (between 15-90% brightness), and I've discovered that leaving pavucontrol running in the background stops the audio popping.
Need help with new pinebook pro - by magistral - 08-25-2022, 11:35 PM
RE: Need help with new pinebook pro - by steeb - 08-31-2022, 08:41 AM
RE: Need help with new pinebook pro - by steeb - 09-05-2022, 09:30 PM
RE: Need help with new pinebook pro - by Shad0w - 09-03-2022, 06:26 PM
RE: Need help with new pinebook pro - by steeb - 09-04-2022, 09:10 PM
RE: Need help with new pinebook pro - by Shad0w - 09-05-2022, 06:11 PM
Need help with new pinebook pro - by petersen77 - 09-06-2022, 01:51 PM
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,131 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,257 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,301 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
