PBP booting but stops at flashing power led
I did as you suggested: copied zip files to a partition around 24-26GB. No errors were thrown.
After that, I again flashed Manjaro ARM xfce 22.06 for PBP to the eMMC using Gnome Disks. Then, I flashed the previously saved partition 2 of the old working eMMC to partition 2 of the new eMMC. The saved .img file has 50.3 GB and partition 2 of the new eMMC has 62 GB.
I did this five times and every time the flash process stopped with the following error:
Error writing 1048576 bytes to offset x: Input/output error (g-io-error-quark, 0)
attempt 1: offset = 39154876416
attempt 2: offset = 37957402262
attempt 3: offset = 33597423616
attempt 4: offset = 32544653312
attempt 5: offset = 32437698560
Thus, flashing the partition 2 image of the old (working) eMMC is somehow not possible. But copying zip files is working fine.
RE: PBP booting but stops at flashing power led - by jonasd - 08-21-2022, 03:20 PM
  Pinebook Pro on Debian 12 Power Issue u974615 1 339 03-13-2024, 10:46 AM
Last Post: u974615
  Increasing the maximum power draw dsimic 15 19,636 11-21-2022, 03:36 AM
Last Post: bircoph
  Alternative Power supply options gallomimia 13 17,947 11-13-2022, 06:10 PM
Last Post: pineymousepad
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 1,073 08-12-2022, 06:41 AM
Last Post: JessicaQ
  Blinking red light for charger, no power-on bifo 11 13,798 11-30-2021, 01:37 PM
  power on PBP if your keyboard is dead? stozi 0 1,333 11-29-2021, 01:55 PM
Last Post: stozi
  pinebook pro trackpad randomly stops working chewie 5 5,843 08-10-2021, 04:33 PM
Last Post: chewie
  Motherboard malfunction - a possible warning about power supplies mjc 8 7,107 07-28-2021, 01:04 PM
Last Post: mjc
Question Battery stops charging and NVMe and other media disconnect randomly Eey0zu6O 4 4,799 07-09-2021, 08:45 PM
Last Post: moonwalkers
Question UK Power Supply User 11436 11 17,499 02-09-2021, 12:30 PM
Last Post: dieselnutjob
