Anyone yet received replacement sim/sd card holder
(06-17-2022, 10:51 AM)tckosvic Wrote: I see additional posts about failed sim/sd card holders which I think are from excessive use.
My question stands:  Has anyone yet received a replacement card holder under pinephone's replacement program?  i still have had not even received any communication or acknowledgement .
tom kosvic
Thank you for getting back to the original question. I am very interested in the answer.
My PP SIM pins broke early on. I was able to solder them back and it continues to work. But, when I heard that the PPP uses the name microSIM size and thus requires and adapter I held back on buying a PPP. The sharp edge of the micro-nano adapter broke my pins and it's been the cause described by others, clearly. They should have gone with a nanoSIM for the second generation device.
RE: Anyone yet received replacement sim/sd card holder - by lsitongia - 04-14-2023, 03:29 PM
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,805 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,656 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 7,750 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,213 03-13-2022, 12:20 PM
Last Post: tckosvic
  How to remove the sim card liberty1234 6 4,374 02-16-2022, 01:27 PM
Last Post: ragreenburg
  SD Card insertion depth nristen 4 3,075 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 3,566 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 2,820 01-27-2022, 09:48 PM
Last Post: bcnaz
