Anyone yet received replacement sim/sd card holder
(06-07-2022, 01:13 PM)Chief Wrote:
(06-07-2022, 08:21 AM)tckosvic Wrote: My PPP is borked over sim/sd card issues due to multidinous reinsertions of cards into holder.  Doesn't find sim or make calls as it once did.  The sim card is good as it works in PP.
Per the instructions of pinephone, it was stated that they will send you a new sim/sd card holder if you send your order number and a picture of the card to "pinephone support".  Have done that and no response that they will send a new card or that they even acknowledge receipt of my request.  Sent more than a month ago.
I admit that I took the picture myself and did not take phone to repair shop.  I'm not paying $100 to get a repair shop to send a picture.  I might pay them to install the part later but so far no progress on getting the part.  I might even install a new PPP board if those are ever available on PPP parts site.
So, anyone yet received a replacement sim/sd card holder as promised by pinephone?
thanks,       tom kosvic
My sim card holder was busted as well. One of the pins had broken off. I took it to a repair shop my son suggested to me and 1 day later fixed for $25.00
Works fine now so I suggest if it is at all repairable by your local shop consider this cheap but excellent cost fix.
That stated I have done all the updates possible including towboot and quite a few things are fixed. The problem still remains that the output sound is seriously low regardless of speaker / internal setting and volume maxed out. Also the device still wants to sleep and >sometimes< requires a hard boot. Based on this and the fact that I use documents (important) etc not a reliable device at this time. PP Convergence is still my daily device with 100% reliability and I consider this device to be Pine64's "flagship"
Would you be able to get the part number and name for the item your repair guy installed and post it here? Might break the broken sim/sd card log jam.
Good job.  My PP works infinitely better than my PPP which doesn't make calls.  I use that also.
RE: Anyone yet received replacement sim/sd card holder - by tckosvic - 06-07-2022, 08:51 PM
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,801 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,656 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 7,746 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 4,209 03-13-2022, 12:20 PM
Last Post: tckosvic
  How to remove the sim card liberty1234 6 4,373 02-16-2022, 01:27 PM
Last Post: ragreenburg
  SD Card insertion depth nristen 4 3,073 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 3,566 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 2,819 01-27-2022, 09:48 PM
Last Post: bcnaz
