Battery Life is it possible?? Tech Question (sort of)
(05-04-2022, 04:42 AM)wibble Wrote: Apple do it with sophisticated power management software AND HARDWARE. They're designing their own highly integrated silicon to work with their software to achieve very good power efficiency.
Android shows similar levels of efficiency are possible with linux - for certain definitions of linux. On the hardware side the necessary drivers are often closed (arguably in violation of the GPL) and tied to specific kernel versions. Power efficiency is an area of competitive advantage so manufacturers like to keep it secret. If you want open code it may rule out the most efficient hardware, assuming it would even be available to a small manufacturer like Pine64. Google have been upstreaming a lot of the kernel changes they made that impact power efficiency either directly or indirectly, but aspects like the application lifecycle management aren't generally used by linux distros. That may be a good thing given the complaints about Android phones killing apps that people want to remain running in the background.
Short version - there are improvements to be made in the software, and only in making them are we likely to find out whether there are gotchas in the hardware, but neither the PinePhone nor the Pro will ever be at iPhone levels with the current hardware.
Thank you for the detailed and awesome answer! Much appreciate it!
RE: Battery Life is it possible?? Tech Question (sort of) - by scrwbigtek - 05-04-2022, 10:46 AM
  DisplayPort Out question scoulber@protonmail.com 48 31,870 06-11-2023, 02:20 AM
Last Post: etbe
  PinePhone Pro battery life at the beginning of 2023? dante404 14 8,687 06-03-2023, 07:45 AM
Last Post: crocspot
  Unofficial Pinephone Battery Case lllsondowlll 15 15,671 02-21-2023, 10:34 AM
Last Post: Yaky
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 6,055 05-21-2022, 01:24 PM
Last Post: 98cwitr
  Less than 12 hours on battery - doing nothing tcoulon 8 4,952 04-23-2022, 02:00 AM
Last Post: fxc
  Pinephone Battery doesn't fit in the Pinephone Pro ragreenburg 2 1,787 03-25-2022, 09:21 AM
Last Post: ragreenburg
  Good Spare Battery Replacement thismarty 1 3,497 03-23-2022, 04:15 PM
Last Post: Fred Zyphal
Question Possibly dumb question For_lack_of_a_better_name 1 1,463 03-06-2022, 04:54 AM
Last Post: fxc
  No signs of life For_lack_of_a_better_name 1 1,323 03-03-2022, 03:31 PM
Last Post: fxc
  Battery questions For_lack_of_a_better_name 5 3,104 02-26-2022, 11:45 PM
Last Post: lllsondowlll
