PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD
so.... check LABEL= is right,,,, sudo blkid ,,,, and that the dtb is where stated, not in a dtb directory
the line(s) linux /vmlinuz-5.10.0-13-arm64
Strongly suggest that /boot is a separate partition, should show that in blkid above
If there is only 1 partition, that is wrong
explanation: uboot looks for (and I'm not sure what order) boot.scr, extlinux/extlinux.conf, efi/aarch64.efi
(or boot/boot.scr,, boot/extlinux/extlinux.conf ,,, etc)
If there is only 1 partition, those are preceded by /boot/
If there are 2, well, fstab and mounting has not happened yet, so as far as uboot
knows, these are in the root of what uboot recognizes as the file system
If you have a 3.3V serial cable and flip the headphone/serial switch then you will know more
Even then, some dtb's do not set up video correctly
My extlinux.conf for buster also has (in the append line) modprobe.blacklist=panfrost
and maxcpus=6 (This will just make it a LOT slower,using the 4 m55 cores)
RE: PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD - by wdt - 04-30-2022, 10:48 PM
  Debian on Pinebook Pro u974615 7 1,315 03-31-2024, 10:11 AM
Last Post: u974615
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 378 03-01-2024, 06:46 PM
Last Post: Puckla
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,243 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,336 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 457 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,345 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,154 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,631 09-07-2023, 09:38 PM
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,061 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 2,028 08-21-2023, 09:08 PM
