Tow-boot problems and restoring uboot
(05-18-2022, 11:53 AM)wibble Wrote: Based on the doc linked in post #4 I think zeroing 32k starting at an 8k offset should remove enough of the u-boot from the SD for the pinephone to boot from eMMC, but I haven't tried it. Something like this, assuming I've remembered which device is uSD and which eMMC - do check!
dd if=/dev/zero of=/dev/mmcblk0 bs=1024 seek=8 count=32
 i have tried it and it booted from emmc like it should
 but when i tried to tell tow-boot to boot from sd card the boot hanged
 so i think that dd command wipes too much of u-boot
 and it is for use the sd card as storage only
 ezik
multi-distro sd doesn't boot either when i tell it to boot feom emmc
and then tell tow-boot to boot from sd again
after the aqua led the phone vibrate three times with red led then yellow
and fall back to boot from emmc (manjaro phosh if it matters)
ezik
RE: Tow-boot problems and restoring uboot - by shulamy - 08-10-2022, 01:50 AM
  boot gets stuck shortly after disk decryption vortex 9 9,187 09-11-2024, 05:40 AM
Last Post: normangraves
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 7,614 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 3,475 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 1,808 09-01-2023, 11:29 AM
Last Post: Mahgue
  Stability problems with 6.1 kernel Zebulon Walton 9 6,959 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 2,241 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 3,581 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 2,201 03-06-2023, 12:06 PM
Last Post: freelectro
  [solved] Black screen at boot time mdk 0 2,034 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 2,309 01-04-2023, 06:46 PM
Last Post: 3x5co
