Tow-boot problems and restoring uboot
Since I started this thread I should probably follow up and say I never did get around to reflashing the eMMC with a non-tow-boot image. The problems I described have not happened again so for now I'm just going to leave it as-is. I'll be sure to keep an image without tow-boot around just in case. (I do love the convenience of the built-in Jumpdrive functionality for making image backups.)
RE: Tow-boot problems and restoring uboot - by Zebulon Walton - 05-18-2022, 12:33 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,067 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 980 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  Stability problems with 6.1 kernel Zebulon Walton 9 2,663 05-12-2023, 08:09 AM
Last Post: zetabeta
  4G data on default startup / boot dcinoz 1 859 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,360 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 983 03-06-2023, 12:06 PM
Last Post: freelectro
  boot gets stuck shortly after disk decryption vortex 8 4,073 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,026 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,014 01-04-2023, 06:46 PM
Last Post: 3x5co
