Moving to Tow-Boot: Towards Device-Independant Images
u-boot-menu is still required according to the FAQ in the blog post, so if you tried removing u-boot-* that might explain why it wanted to remove others. Use apt-rdepends if you really want to find out what's keeping each one from being autoremoved.
RE: Moving to Tow-Boot: Towards Device-Independant Images - by wibble - 04-15-2022, 05:41 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,130 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 1,029 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 666 09-01-2023, 11:29 AM
Last Post: Mahgue
  Moving to trixie user641 7 2,108 07-09-2023, 06:05 AM
Last Post: user641
  4G data on default startup / boot dcinoz 1 882 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,394 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 1,002 03-06-2023, 12:06 PM
Last Post: freelectro
  boot gets stuck shortly after disk decryption vortex 8 4,154 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,038 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,036 01-04-2023, 06:46 PM
Last Post: 3x5co
