Moving to Tow-Boot: Towards Device-Independant Images
Yes, you can install tow-boot in place of uboot on an existing mobian emmc install. I've just done it on mine which was installed via the installer image with encrypted rootfs. I just made sure mobian had a full upgrade and autoremove, which removed the old u-boot-sunxi package. I checked to see /boot/extlinux/extlinux.conf was present since that's what tow-boot will read to see what to boot, then followed the tow-boot installation instructions:
https://tow-boot.org/devices/pine64-pinephoneA64.html
It now boots emmc mobian as before by default, and volume up boots onto the usb disk mode that's similar to JumpDrive as the instructions say it should. I haven't tried booting uSD cards yet, and I don't think tow-boot can do anything about the A64 using a bootloader on the uSD first if one is present.
RE: Moving to Tow-Boot: Towards Device-Independant Images - by wibble - 04-13-2022, 06:02 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,021 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 956 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
  Moving to trixie user641 7 1,983 07-09-2023, 06:05 AM
Last Post: user641
  4G data on default startup / boot dcinoz 1 845 04-29-2023, 11:24 PM
Last Post: dcinoz
  PinePhone won't boot after software update jb2000 2 1,346 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 971 03-06-2023, 12:06 PM
Last Post: freelectro
  boot gets stuck shortly after disk decryption vortex 8 4,036 02-13-2023, 02:11 AM
Last Post: sharase
  [solved] Black screen at boot time mdk 0 1,017 01-13-2023, 03:33 AM
Last Post: mdk
  No boot after upgrade: vibration, red LED, then 2 vibrations and yellow LED 3x5co 1 1,000 01-04-2023, 06:46 PM
Last Post: 3x5co
