Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh
ps -ef
should give you a full process list. See the man page to get details of these options and the others available:
man ps
Pipe into less if scrolling is tricky, or grep if you know what you're looking for and just want to see the filtered results.
You can then use the kill command with the process ID. Perhaps also look at pgrep, pkill and killall commands and their man pages.
It may be that there is no process, just a left over lock file that needs removing manually.
RE: Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh - by wibble - 04-07-2022, 05:16 AM
  link for supported pinephone os manjharo et all penguins_rule 3 375 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 525 04-02-2024, 11:52 AM
  Manjaro: Settings doesnt open nbh 0 628 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,793 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 1,702 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 1,932 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 851 04-25-2023, 09:49 AM
Last Post: jakfish
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 5,033 03-02-2023, 07:25 PM
  Can't add micro SD card to Pinephone thorensjubilee 7 2,696 02-27-2023, 10:21 AM
Last Post: mikehenson
  Backup and Home Screen Tinkering on Phosh jakfish 0 901 02-24-2023, 12:56 PM
Last Post: jakfish
