Replace PPP sim card/sd card slot hardware
(03-03-2022, 09:10 AM)tckosvic Wrote: Looking for replacement for SA-2202-112 25-pin Micro-SIM and TF slot as referenced from PPP parts list.
PPP will not read my consumer cellular sim card and it is difficult to insert or remove sd cards.  It used to read sim card fine and I could make phone calls, sms, and mms using manjaro-phosh.  Now nothing.   No software fixes work so it must be the hardware.  Perhaps too many inserts/removals.
I can't find replacement on PPP spare parts site.  Search for part doesn't pick up anything on internet.  Amazon has some slot hardware but nothing looks simillar.
Anyone found a hardware source?  Anyone changed one out successfully?
thanks,     tom kosvic
Additionally,  the slot hardware is not listed in PPP spare parts website.  I left a message at pinephone info asking them for a purchase recommendation.
RE: Replace PPP sim card/sd card slot hardware - by tckosvic - 03-03-2022, 10:33 AM
  Anyone yet received replacement sim/sd card holder tckosvic 19 9,397 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 2,806 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 1,656 08-22-2022, 06:42 PM
  Replace Pogo Pins / Melted Pogo Pins fix magdesign 0 1,783 08-01-2022, 02:49 PM
Last Post: magdesign
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 7,763 06-15-2022, 02:32 AM
Last Post: fxc
  How to remove the sim card liberty1234 6 4,375 02-16-2022, 01:27 PM
Last Post: ragreenburg
  How to access the hardware privacy switches? Pinoideae 3 2,212 02-09-2022, 10:45 PM
Last Post: bcnaz
  SD Card insertion depth nristen 4 3,080 02-03-2022, 01:27 PM
Last Post: nristen
  Bent SD card pin bhboyle 5 3,566 02-03-2022, 09:54 AM
Last Post: kqlnut
  SD card slot specs frimmel 3 2,820 01-27-2022, 09:48 PM
Last Post: bcnaz
