Glacially slow system updates on Mobian - waiting on boot 20m - 1h
(02-22-2022, 10:34 AM)bujiraso Wrote: What are the average system update times for anyone else here?
Is there a way to speed this up? Is it affected by system encryption?
It used to be discouraged to use "Software" and the Graphical User Interface for updates because it was known to cause problems (not sure if that's still the case). It was recommended to to use the terminal instead:
sudo apt update && sudo apt upgrade -y -y
That's how I've always done it without ever experiencing any problems or delays of glacial proportions. Never takes more than five minutes to upgrade (which I do on a daily basis though).
RE: Glacially slow system updates on Mobian - waiting on boot 20m - 1h - by Anna - 02-23-2022, 11:45 AM
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 17 2,119 Yesterday, 05:47 AM
Last Post: diederik
  Mobian repository status henrythemouse 16 8,816 04-10-2024, 10:02 AM
Last Post: diederik
  cant verify mobian image at website gnugpg penguins_rule 0 140 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,021 11-22-2023, 11:46 AM
Last Post: aLoop100o
  Errors when start the system kubussz 2 580 11-21-2023, 11:07 AM
Last Post: kubussz
  How to check if tow-boot is installed? jojuma 3 956 09-29-2023, 11:29 PM
  System won't suspend due to suspention notification user641 6 1,433 09-24-2023, 05:47 AM
Last Post: user641
  No volume control after latest updates Zebulon Walton 19 7,190 09-08-2023, 08:28 AM
Last Post: jessencan
  What actions needed to keep on mobian testing user641 3 1,840 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 643 09-01-2023, 11:29 AM
Last Post: Mahgue
