Bent SD card pin
Good morning.
Yesterday I received my new Pinephone Pro. As you can imagine I was excited.
Right away my excitment turned to sadness. I noticed there is a problem with the updates. I will not update at all due to some errors. It would not work via the gui or the command line. No problem I thought, I will just reinstall the OS. It was at this point that I saw the bent pin in the SD card reader. The pins are failrly badly bent. It refuses to boot of any SD card I have.
So now I have a $399 paper weight. Sad
Bent SD card pin - by bhboyle - 02-01-2022, 07:52 AM
RE: Bent SD card pin - by bhboyle - 02-01-2022, 01:12 PM
RE: Bent SD card pin - by kqlnut - 02-01-2022, 01:57 PM
RE: Bent SD card pin - by bhboyle - 02-01-2022, 05:43 PM
RE: Bent SD card pin - by bhboyle - 02-02-2022, 09:45 AM
RE: Bent SD card pin - by kqlnut - 02-03-2022, 09:54 AM
  How to remove the sim card liberty1234 7 7,634 07-17-2024, 09:57 AM
Last Post: Blackheart
  Anyone yet received replacement sim/sd card holder tckosvic 19 16,547 06-16-2023, 12:20 PM
Last Post: fxc
Photo My PinePhone Pro does not read the micro SD card at all. tux_life 7 5,789 03-26-2023, 02:55 AM
Last Post: tux_life
  PinePhone Pro Motherboard with sim card holder tckosvic 1 2,633 08-22-2022, 06:42 PM
  Warning!!- sim card adapter destroyed my sim card holder on my pine phone pro ANDROID2468 11 12,031 06-15-2022, 02:32 AM
Last Post: fxc
  Replace PPP sim card/sd card slot hardware tckosvic 5 6,344 03-13-2022, 12:20 PM
Last Post: tckosvic
  SD Card insertion depth nristen 4 4,891 02-03-2022, 01:27 PM
Last Post: nristen
  SD card slot specs frimmel 3 4,446 01-27-2022, 09:48 PM
Last Post: bcnaz
