Wont charge when powered off, and update question
It looks like you were first in the right place to find the proper firmware updater. Mangaro nor any other operating system that I'm aware of will (nor should) do this.
Keep in mind that what you are doing to fix the touchpad is an actual firmware update, as in real firmware, not a software update a la Linux "firmware".
:wq
[ SRA accepts you ]
RE: Wont charge when powered off, and update question - by KC9UDX - 12-06-2021, 07:26 PM
  uboot wont boot to SD card after upgrade jbradley419 7 830 01-19-2024, 02:29 PM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,224 12-15-2023, 02:11 PM
  Newbie Question!! oniichann 3 887 10-26-2023, 07:09 AM
  After update, multiple problems, pinebook pro. jd50i 1 1,047 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 1,060 02-22-2023, 03:23 PM
Last Post: robocone
  GPIO breakout question pinus_pinea 0 677 01-17-2023, 06:13 AM
Last Post: pinus_pinea
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 3,320 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 1,421 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
Question Pinebook Pro shows only bright white screen when powered on Sean Whitton 3 2,000 07-22-2022, 01:19 PM
  Ring around screen following update tylerjohnson3208 2 2,095 05-10-2022, 01:52 AM
Last Post: diyagabriel
