No incoming SMS. Outgoing SMS, calls and data working.
I may have found a fix, based on info from this thread:
https://forum.pine64.org/showthread.php?...5#pid65065
Using atinout, I did
sudo atinout - /dev/EG25.AT out.txt << EOF
> AT+CMGD=?      #To show what's in the Modem's memory buffers
> AT+CMGD=0,4   #Iterates through the memory buffers between 0,4 and deletes each
> AT+CMDG=?      #To double check it worked.
What I got was
+CMGDSad0,1,2,3,4,5,6,7,etc...)(0-4)
OK (Which shows that the memory buffers are full, 0-4 are the relevant buffers, which I found and then deleted)
OK (Shows we completed iterating through the buffers successfully)
+CMGD: (),(0-4)
OK (Double check that it worked, and it did!)
Sent a text to my phone and it came through! Not sure why it wasn't coming up in mmcli or Modem Manager GUI, it looked like it might be Verizon system data rather than actual SMS or MMS messages? I didn't do much investigation because I'm very tired and just wanted texts working on my phone again, but if I get the chance to examine what exactly was clogging it up I may come back and share that information.
I'm going to make a chron job like in that thread to have this code run every hour or so to make sure this doesn't happen again. Hopefully this thread will help if anybody on the Verizon network has the same problem, because that seems to be a common thread.
RE: No incoming SMS. Outgoing SMS, calls and data working. - by HardwarePunk - 11-20-2021, 12:53 AM
  debugging issue realted to iso image wth extra data eror penguins_rule 3 276 04-23-2024, 03:15 AM
Last Post: tapirsurfeit
  Calls/Texts and External Monitor gregb49 0 695 06-30-2023, 11:38 AM
Last Post: gregb49
  Internal Microphone issue during calls Viktor 6 2,557 03-31-2023, 08:58 AM
Last Post: Viktor
  New issue with phone calls kmsgli 13 6,696 08-15-2022, 01:45 PM
Last Post: Gon
Question Troubleshooting incoming SMS/MMS epiii2 5 2,949 05-18-2022, 11:15 AM
Last Post: epiii2
  Keyboard case stopped working on pacman update rotwang 5 3,171 05-07-2022, 09:17 PM
Last Post: rotwang
  Can't call or receive calls PJK2012 3 2,911 04-26-2022, 03:05 PM
Last Post: PJK2012
  Manjaro Plasma Beta and Cellular Data Service Fred Zyphal 7 5,104 03-17-2022, 05:50 PM
Last Post: Fred Zyphal
  Calls & SMS stopped working Schugy 3 2,397 12-28-2021, 05:00 AM
Last Post: Schugy
  Ctrl-O on virtual keyboard not working in nano PJK2012 3 3,177 11-11-2021, 08:47 PM
Last Post: PJK2012
