Best OS where most of the things work?
(12-09-2021, 06:44 PM)nelstomlinson Wrote: Ryo, that suspends the machine, just leaves the modem awake enough to receive calls and texts, right?
Correct.
(12-09-2021, 06:44 PM)nelstomlinson Wrote: It suspends, then pops back awake in a few seconds, to the lock screen.
Happens sometimes if you put it to crust mode and immediately put it in your pocket.
Best is to wait a couple of seconds before doing that, and make sure you won't touch the power button, since that's the only input device that remains enabled while under crust.
母語は日本語ですが、英語も喋れます(ry
RE: Best OS where most of the things work? - by ryo - 12-09-2021, 07:28 PM
  PureTalk work with Pinephone? car46999 6 2,898 01-30-2023, 12:05 AM
Last Post: car46999
  likely bug, volte does not work when operator side data blockage is activated zetabeta 1 1,277 05-21-2022, 03:03 PM
Last Post: zetabeta
  SD nonfunctional, how is support supposed to work? slomobile 6 4,036 01-18-2022, 07:02 PM
Last Post: slomobile
Sad LTE data does not work on T-Mobile US with latest postmarketOS 21.06 SP3 PacificSinewave 1 1,402 11-07-2021, 10:15 AM
Last Post: beta-user
  Lets discuss the GPS. Who has got it to work? AwHereWeGoAgain 8 6,387 09-17-2021, 01:29 PM
Last Post: KNERD
  What OS will actually work with phone calls? Nutmeg 16 12,060 08-07-2021, 11:01 AM
Last Post: mouffa
  Will the Pinephone work with Vodafone in Romania? MirceaKitsune 2 2,786 05-30-2021, 09:42 AM
Last Post: MirceaKitsune
  First Time Password 123456 does not work (SOLVED) OggieDoggie 0 1,731 11-06-2020, 09:14 PM
Last Post: OggieDoggie
  With what image(s) does phoning fully work? LinAdmin2 13 14,072 10-04-2020, 09:06 PM
Last Post: SwordfishII
  Can I buy and use a PinePhone in China? Will it work out of China? Dumbr 2 4,092 09-21-2020, 03:25 PM
