Debian/unstable SD card rescue image
(10-26-2021, 02:17 AM)wangyukunshan Wrote: [...] it takes some luck to log in to the graphical interface. Sometimes you enter the command line and sometimes you enter the login interface. [...]
I assume you downloaded the first version of the SD card image i provided, and which has both wmlive-gdm and lightdm installed in parallel.
As it turns out, even if one of the two session managers is definitely chosen as the default one (via "dpkg-reconfigure -plow lightdm", e.g.), until the other one has either not been completely deinstalled or at least disabled (via "systemctl disable wmlive-gdm" or "systemctl disable lightdm"), there is a race condition during startup that results in the behaviour you observed.
So if my guess is correct and you are using the older SD card image, then just disable or remove one of the present session managers and future startups will launch the X11 session in the expected normal manner.
Please let me know if this solves your issue. Thanks!
Devices: Pinebook Pro & Pinephone (Braveheart)
Debian/unstable SD card rescue image - by vajak - 10-04-2021, 05:43 PM
RE: Debian/unstable SD card rescue image - by vajak - 10-28-2021, 02:53 PM
  Debian on Pinebook Pro u974615 7 1,006 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,577 02-22-2024, 04:02 PM
  install debian on pbp jsch 7 4,029 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,402 09-07-2023, 09:38 PM
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,969 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,044 07-15-2023, 02:58 PM
Last Post: u974615
  2TB SD Card Write Errors jiacovelli 3 1,045 06-02-2023, 06:13 PM
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,277 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,337 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,041 10-19-2022, 03:09 AM
Last Post: alpopa
