PineBook Pro dead
(01-15-2023, 12:29 PM)ottahe Wrote: New year again and finally a success. I created a new sdcard with armbian and could boot from it. The eMMC was not visible in the lsblk output.
I opened the case and was looking for eMMC switch when I noticed that the eMMC was loose. I pressed on it until it locked. After that, I could
see it in lsblk. After removing the sdcard, I turned it on and saw the green led, but it wouldn't boot from eMMC. Back with the sdcard, I could mount
the 2 partitions on the eMMC and it looks normal (uboot and linux). For now, I'll be using it with the sdcard and decide later, what to do with the eMMC.
You'll need to take the bottom cover off, turn the eMMC switch off, boot with the micro-sd card, then turn the eMMC back on, and re-bind it.  Then you can zero it and put everything back together.
Before taking the bottom cover off, open the lid and leave the monitor half hanging over the edge of a table.  The case is incredibly fragile with the bottom removed.
:wq
[ SRA accepts you ]
PineBook Pro dead - by ottahe - 08-22-2021, 01:07 PM
RE: PineBook Pro dead - by tophneal - 08-23-2021, 09:11 AM
RE: PineBook Pro dead - by KC9UDX - 08-23-2021, 04:47 PM
RE: PineBook Pro dead - by ottahe - 11-03-2022, 01:33 PM
RE: PineBook Pro dead - by pineymousepad - 11-13-2022, 06:12 PM
RE: PineBook Pro dead - by wdt - 11-03-2022, 02:28 PM
RE: PineBook Pro dead - by ottahe - 01-15-2023, 12:29 PM
RE: PineBook Pro dead - by KC9UDX - 01-16-2023, 07:51 AM
RE: PineBook Pro dead - by wdt - 01-17-2023, 05:24 AM
RE: PineBook Pro dead - by ottahe - 01-18-2023, 07:41 PM
  HDMI or VGA From Pinebook Pro via Pinebook Pro Docking Deck? segaloco 4 604 Yesterday, 09:27 AM
  Pinebook Pro on Debian 12 Power Issue u974615 1 355 03-13-2024, 10:46 AM
Last Post: u974615
  Pinebook Pro Source for Trackpad Flex / Ribbon Cable rankharris 1 296 02-17-2024, 07:06 PM
  Pinebook Pro charging issues tomekdev 1 638 01-05-2024, 08:40 PM
Last Post: tomekdev
  Replacement battery for PineBook Pro DrYak 3 1,137 11-07-2023, 10:09 AM
Last Post: DrYak
  Pinebook Pro Revised Keyboard Firmware jackhumbert 73 131,048 09-13-2023, 03:43 AM
Last Post: k3dAR
  Pinebook Pro malfunctioned hardware samtux 10 4,493 12-27-2022, 03:31 PM
Last Post: samtux
  PineBook Pro revision 2.2: Wishlist for the hardware issue fixes dsimic 115 137,313 11-30-2022, 04:28 PM
  Decent Pinebook Pro barrel PSU / Charger petaramesh 3 1,930 10-21-2022, 07:57 AM
Last Post: dachalife
  Dead, dead, dead! vgivanovic 6 4,331 08-27-2022, 02:00 PM
Last Post: vgivanovic
