which distro + DE are you using these days on the Pinebook Pro?
slarm64+xfce on luks+lvm = my pinebook pro
The slarm64 xfce images (on the slarm64 thread in this forum) function well:  display, power, wifi, bluetooth, audio... everything smooth and snappy!  Burn it to microsd, and boot.  It starts at xfce-login for non root user, which has to be created first:  I used cntrl-alt-f2 to switch ttys, and logged in as root (it tells you at the prompt that  the root password is password)... logging in as root for the first time launches a script that creates the initial unprivileged user... Once done with that script, I switch back to the initial tty with ctrl-alt-f7, and the log in to xfce as the new user...   After that it's a brief perusal of slackware documentation especially how to use slackpkg and sbopkg to install and maintain stock and third party packages and how to keep the system current.  Slackware is configured by editing config files, most all of which reside in /etc, and the ones pertaining to boot and startup (runtime configurations), reside at /etc/rc.d.   I have found the time and energy I spent learning slackware to be repaid immeasurably in knowledge--I used to do the same thing over and over again on computers, and now I can automate myself, mostly thanks to excellent slackware documentation... If I wasn't a slacker, I would be a gentooman, because it too has excellent documentation... but I dove deep enough into slackware to prefer it on all devices.
RE: which distro + DE are you using these days on the Pinebook Pro? - by globaltree - 07-24-2021, 12:32 PM
  Debian on Pinebook Pro u974615 7 1,062 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,621 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,163 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,133 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,260 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,301 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,489 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,596 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 667 07-13-2023, 05:21 PM
Last Post: owaspfap
